Understanding the Validity of PDE Solutions with Variable Substitution
  • Thread starter Thread starter bullet_ballet
    Pde
The discussion revolves around the validity of solutions to the partial differential equation (PDE) u_t + c u_x = 0, particularly focusing on the function u(x, t) = f(x - ct) where f is a C¹ function. Participants explore the implications of variable substitution in the context of PDEs and the conditions under which these substitutions yield valid solutions.
  • Participants question the reasoning behind using the substitution x - ct to demonstrate that f(x - ct) is a solution to the PDE. Some express uncertainty about the necessity of multiple linearly independent solutions for generalization. Others discuss the role of boundary conditions in determining the validity of specific solutions.
The conversation is active, with participants offering insights into the nature of solutions and the importance of boundary conditions. There is a recognition that without boundary conditions, a PDE can have multiple solutions, and some participants suggest that the general form of the solution is u = f(x - ct), contingent on specific conditions.
There is an ongoing exploration of the relationship between specific solutions and general solutions in the context of PDEs, with emphasis on the role of boundary conditions in defining the uniqueness of solutions.
bullet_ballet
"Verify that, for any C¹ function f(x), u(x, t) = f(x - ct) is a solution of the PDE u_t + c u_x = 0, where c is a constant and u_t and u_x are partial derivatives."
I managed to get the solution for this and a similar problem by showing that the new variable (x - ct in this case) satisfies the PDE, but why does doing that work? Is it because if x-ct is a solution so is any function of it? That just doesn't sound right since you'd need at least two linearly independent solutions to make that kind of generalization. Or maybe I'm just an idiot. :)
Mucho thanks if anyone can point out what basic thing I'm missing.
I managed to get the solution for this and a similar problem by acting on what the new variable is (x - ct in this case), but why does doing that work? Is it because if x-ct is a solution so is any function of it? That just doesn't sound right since you'd need at least two linearly independent solutions to make that kind of generalization. Or maybe I'm just an idiot. :)
f(x-ct) represents a function that is moving along the x-axis with velocity c. The variable x-ct is widely used in wave propagation phenomena, because making this traslation you are traveling just over the wave edge, so that some variables remain constant viewed at that point. It is true that f(x-ct) is the solution of your PDE (named a characteristic equation), but f has to be figured out by means of your boundary conditions.
I'm not sure of having answered you completely.
I don't think I was specific enough. I was asking why I could use x-ct to satisfy the PDE and show that f(x-ct) is therefore a solution.
Having done this for a couple of different problems, it seemed like I could draw the conclusion that if the PDE held for some a(x,t), then the solution to the PDE could be stated as u(x,t) = f(a(x,t)).
x-ct is NOT a solution of your PDE. It's only a "special variable" which enhances a simpler solution. Why, because viewing your PDE one can establish:
[tex]\frac{dx}{dt}=c[/tex] ----> along the rect [tex]x-ct=x_o[/tex] u(x,t)=f(xo) is a constant.
f is a solution of your PDE but x-ct is not a solution.
Sure, Clausius2!
u(x,t)=x-ct is certainly A solution of that differential equation.
(f is here the identity function)
arildno said:
Sure, Clausius2!
You are not allowed to substitute any value for f if you do not know (as me) the boundary conditions. So that, for the problem he posted, f=1 is not a general solution. Perhaps some boundary conditions enhances your reply, but this is not the case.
Without boundary conditions, a differential equation has a multitude of solutions.
If you put on boundary conditions and the problem is well-posed, you'll have a unique f satisfying BOTH the differential equation and the boundary conditions.
I never said f=x-ct (or f=1) are a GENERAL solution, I said it was A solution.
Ok Norwegian (well written?, sorry if not) friend, If you want we could come up with a settlement:
u=x-ct is only a solution for a concrete boundary conditions.
u=f(x-ct) is the most general solution (not general in the sense you wrote, only in the sense of generallity) for that problem.
Is it Ok?
u=f(x-ct) is certainly, indisputably, factually and necessarily the most general solution (of the differential equation).
There exist a well-posed problem in which u(x,t)=x-ct is the unique solution.
Is that OK?
(I don't think we had much disagreement in the first place..)
Ha Ha Ha! :smile:
OK! We have reached an agreement!
Where are the beers?
(What would say Bullet Ballet of all this stuff? :confused: )
I think :confused: is his answer..:wink:
