Non-differentiable path in path integral?
The discussion centers around the implications of non-differentiable paths in the context of path integrals, particularly in quantum mechanics and quantum field theory. Participants explore the nature of these paths, their contributions to integrals, and the mathematical challenges they present.
  • Some participants propose that non-differentiable paths, including potentially discontinuous ones, are included in path integrals and question whether this presents serious problems.
  • Others argue that if there are only a finite number of non-smooth points, integration can proceed by summing contributions from each segment, but an infinite number of such points could lead to convergence issues.
  • A participant suggests that it seems possible to have an uncountable number of non-smooth points, raising concerns about the implications for path integrals.
  • Another viewpoint is that while most paths may have uncountably many discontinuities, there exist many smooth paths arbitrarily close to any discontinuous path, suggesting that this may not be a significant issue.
  • One participant states that the path integral for quantum mechanics is supported on nondifferentiable functions and assigns measure zero to differentiable functions, but is also supported only on continuous functions.
  • Concerns are raised about the existence of integrals for certain paths, questioning the implications of non-differentiable paths contributing non-zero values to the integral.
  • A later reply clarifies that while non-differentiable paths contribute non-zero values, this does not imply that the path integral itself does not exist, as the phase factor and measure can still be defined in this context.
  • Another participant seeks clarification on how the phase factor and measure make sense on non-differentiable paths, indicating a desire for a more accessible explanation.
Participants express a range of views on the implications of non-differentiable paths, with no clear consensus on whether these paths present serious problems for path integrals. Some agree on the existence of contributions from non-differentiable paths, while others remain uncertain about the consequences of such contributions.
Participants highlight limitations related to the mathematical treatment of non-differentiable paths, including unresolved questions about convergence and the nature of contributions to the path integral.
kof9595995
It seems obvious in path integral, the paths include some non-differentiable path (some even discontinuous, I think), wouldn't it cause any serious problem? For example, the classical lagrangian as the phase factor, is defined on differentiable paths, isn't it?
if there are only a finite number of points on which the path is not smooth, then you can integrate on each segment and sum. If there are a countably infinite number of points where the path is not smooth, then that sum will be an infinite sum which may not converge. If there are an uncountable number of points where the path is not smooth, then you have a real problem!
Then would "uncountable number of points where the path is not smooth" happen? It seems quite possible to me, since there's not at all any restriction on how you choose |q><q| to insert.
In fact, I think *almost all* of the paths would have uncountably many discontinuities. But for each discontinuous path, there will be many smooth paths which are arbitrarily close to the discontinuous one. So I don't think there's any reason to worry.
Why not? In principle we need to evaluate all possible paths, don't we?
The path integral for quantum mechanics is only supported on nondifferentiable functions. It assigns measure zero to the set of differentiable functions. However it is also supported only on continuous functions.
The support is on even more singular objects in quantum field theory, where the measure is only supported on distributions, not functions.
@DarMM: so you mean only non-differentiable paths gives non-zero contributions to the integral? But it doesn't seem to answer my question, what happened if the integrals for some paths do not exist?
I know very little about this, but in the elementary introductions I have read to the path integral, I believe it is equal to an integral over all continuous paths composed of straight line segments, in the limit where the number of line segments composing the path goes to infinity. You calculate the action for each line segment, add up all the line segments to get the action for the entire path, and then integrate the exponential of the action over all such paths. You ignore the "kinks" joining line segments. In the limit of many line segments, this integral looks like an expression you can write down in QM for the amplitude for the particle to propagate from the start point to the end point.
Yes, only non-differentiable give a non-zero contribution. However this doesn't mean the path integral doesn't exist. The measure the phase factor (in Euclidean time) is [tex]e^{-S[q]}[/tex] which doesn't make any sense on those paths, since the Lagrangian contains derivatives as you said. However the phase factor and the measure [tex]\mathcal{D}[q][/tex] together make sense on those paths. So the path integral exists in quantum mechanics.
Could you brief me how is this so? Well, but you should know I know very little about measure theory(mathematical analysis is in my reach), please explain it in a layman style if possible, many thanks.
  • · Replies 45 ·
  • · Replies 16 ·
