What is the source of light emitted from combustion reactions?
  • Context: Undergrad
  • Thread starter Thread starter Infrasound
    Combustion Light
The discussion revolves around the source of light emitted from combustion reactions, specifically in the context of wood burning. Participants explore various mechanisms that may contribute to the emission of light, including electronic transitions and blackbody radiation.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant suggests that photons may be produced from electron exchanges during the combination of carbon and oxygen atoms.
  • Another participant proposes that energy from combustion causes collisions between atoms/molecules, leading to electrons reaching higher energy levels and subsequently emitting photons, likening this to blackbody radiation.
  • A third participant asserts that both mechanisms are involved and notes that not only electronic states but also vibrational and rotational states of molecules can emit radiation.
  • This participant also distinguishes between the red glow of embers as blackbody radiation and the flame color resulting from electronic transitions and ionization specific to the burning substance.
Participants generally agree that both electronic transitions and vibrational/rotational states contribute to light emission in combustion, but the nuances of each mechanism remain a topic of exploration.
The discussion does not resolve the specific contributions of each proposed mechanism or the conditions under which they apply, leaving some assumptions and definitions open to interpretation.
Infrasound
As a bit of a lay-person when it comes to physics...
When considering combustion reactions (example: wood burning), I am a bit unsure about the source of the light of the flame.
My current thoughts are the following:
Maybe:
1. The photons are produced from the exchange of an electron during the combination of carbon and oxygen atoms. Some transition takes place in which a photon is emitted.
Or
2. Energy from the combustion process causes collisions between other atoms/molecules, and due to the collisions, electrons reach a higher energy level, and then decay back, releasing a photon in the process. Wouldn't this be something like blackbody radiation?
Or
3. Maybe a combination of both of the processes?
Any help is greatly appreciated. Hopefully someone can steer me in the right direction. Thanks in advance.
I think that what you are describing in 1 and 2 are the same thing. The atoms collide and start to give off heat. The vibrations (heat) then gives off light as the result of things jumping between energy levels.
Yes, it's both. Note that it's not just electronic states that are discrete and can change by emitting/absorbing radiation. It applies to the vibrational and rotational states of the molecules as well.
The red glow of embers is blackbody radiation. The flame color is due to electronic transitions/ionization in the burning gas, which is why it's specific to the substance that's burning.
Thank you very much.
  • · Replies 38 ·
  • · Replies 23 ·
  • · Replies 46 ·
  • · Replies 25 ·
21K
