Complex impedance of parallel RC circuit
The discussion focuses on calculating the complex impedance of a parallel RC circuit with a resistance of 80 Ohms and a capacitance of 30 µF at a frequency of 200 Hz. The expected answer is 40 - j40, but the user arrives at approximately 8 - j23. The calculations provided utilize the formula for parallel impedance, confirming that the user's methodology is correct, and the discrepancy lies in the expected answer from the book, which is likely incorrect.
  • Understanding of complex impedance in electrical circuits
  • Familiarity with parallel RC circuit analysis
  • Knowledge of frequency response and its impact on impedance
  • Proficiency in using mathematical formulas for circuit calculations
  • Review the derivation of complex impedance for parallel circuits
  • Learn about the impact of frequency on RC circuit behavior
  • Explore common errors in impedance calculations
  • Investigate the use of simulation tools for circuit analysis
Electrical engineering students, circuit designers, and professionals involved in analyzing and designing RC circuits will benefit from this discussion.
eng_stud
In my book (Storey), there's an exercise with a parallel RC circuit, where R = 80 Ohm and C = 30 uF. The answer for the complex impedance is supposed to be 40-j40, however I can't seem to get there! I've showed my working under. Am I doing something wrong, or is the book's answer wrong? (freq =200 Hz)
[tex]\frac{Z_R Z_C}{Z_R +Z_C} = \frac{-RjX_C}{R-jX_C} \frac{R+jX_C}{R+jX_C}[/tex]
[tex]\frac{RX_C^2 -R^2 j X_C}{R^2 + X_C^2} = \frac{R(1/\omega C)^2 - jR^2 (1/\omega C)}{R^2 + (1/\omega C)^2}[/tex]
[tex]= \frac{80*(\frac{1}{2 \pi *200 * 30 *10^{-6}})^2 - j80^2 * (\frac{1}{2\pi * 200* 30 *20^{-6}} ) }{80^2 + (\frac{1}{2\pi * 200 * 30*10^{-6}})^2}[/tex]
[tex]= \frac{56289.5 - j169765.3}{7103.6} \approx = 8 - j23[/tex]
Am I just too tired when doing these calculations?;-)
Thanks!
Your work is fine.
Thanks!
  • · Replies 17 ·
