Attenuating a Signal: Steps, Minimal Loss & More
  • Thread starter Thread starter eingerichtet
    Signal
The discussion revolves around the challenge of attenuating a DC signal from a maximum of 400V to a range of ±10V. Participants explore various methods for achieving this attenuation while minimizing signal loss and maintaining clarity, addressing both theoretical and practical considerations.
  • One participant suggests using a voltage divider to attenuate the signal, noting that only a small current would pass through it.
  • Another participant questions the feasibility of using a voltage divider for converting a 0 to 400V signal to a -10 to +10V range, indicating that it may not be suitable.
  • Some participants propose the use of a DC to DC switching converter as an alternative, although concerns are raised about the size and availability of such converters for high power outputs.
  • A suggestion is made to set up a follower circuit with a precision voltage reference and a second op-amp stage to achieve the desired voltage range, with additional considerations for protection and accuracy.
  • There is a discussion about the need for clear requirements from the original poster (OP) to guide the conversation, as ambiguity leads to speculation.
  • One participant emphasizes that achieving high power output would require a custom DC to DC converter, which is complex and challenging.
Participants express differing views on the appropriateness of using a voltage divider for the specified conversion. While some advocate for its use, others argue that it may not be feasible given the voltage range and power requirements. The discussion remains unresolved with multiple competing approaches and perspectives.
Participants highlight limitations in the original post, such as the lack of clarity regarding the signal's source and specific requirements for the attenuation process. There are also concerns about the power handling capabilities of suggested methods.
eingerichtet
I've got a signal coming that can theoretically reach a maximum of 400V and at around 5A. This is not an AC signal, it's DC.
However, I need to attenuate this signal down to a maximum of +- 10V. What steps do I need to take? How do I go about this? How to minimize loss of signal clarity?
How about a http://en.wikipedia.org/wiki/Voltage_divider" ?
Can you say what the source of this "signal" is? That's an aweful lot of power for a "signal".
If you want to just monitor the voltage, use a voltage divider as gnurf suggests. The 5A does not go through the voltage divider, though. Only a small current will go through the divider.
If you need to know both the voltage and current, then you would use a voltage divider to measure the voltage, and a current sensor (for DC you need to use a Hall Effect probe, or a very small resistance value "shunt" series resistor that you measure the differential voltage across).
[PLAIN]http://dl.dropbox.com/u/4222062/level%20shift.PNG
This is a simulation, but it may give you a starting point. You may have to devise a voltage divider to give you +13 volts. I'd make it variable so that you can adjust the output level.
Also, R4 may need to be varied a little to get a suitable amplitude in the output signal.
I have split up the input resistor into R3, R2, R1 and R7 because of the large and dangerous input voltage.
If you want to step down the voltage without stepping down the power capability, that could be hard. A DC to DC switching converter is a common approach but it is going to be big size wise. I never seen one off the shelf that kind of power...You are talking about 200A output at 10V.
If you just want to divid the voltage down, then it's easy like everybody said.
Not all that easy. The post asks for a conversion of 0 to 400 volts to -10 to +10 volts.
So, you couldn't do that with a voltage divider.
I read that as "a maximum of approx. 10VDC", but who knows what he meant. Of course, it would help if the OP could make the effort to respond to questions that arise in his thread. The hivemind needs information to function!
If no high current required, I would consider easy. Getting hundred of of amperes, that is hard. Don't think you can get one off the shelf.
couldn't you set up a follower circuit with a precision voltage reference for an offset, then a second opamp stage to get the range you want?
i'm too lazy to go any further than that, but in addition, i'd maybe consider some kind of voltage clamp on the power rails and signal output as fubar protection. plus tweaker pots and whatever else you need to get desired accuracy.
Interesting term! :smile:
Your "follower circuit" would need to be pretty hefty to drop 390V with 5A. I don't think a simple DC-based converter would be suitable. You need a switch mode circuit to limit the power loss.
no, i mean after the voltage divider, to re-reference it. so that 0V would now be the -10V and +10V at your max.
As long as you are not trying to get high power out of it, it shouldn't be too hard. The op need to give more specific requirement. It can be as easy as using voltage divider, an +ve to -ve voltage inverter to do it ( not efficient using voltage divider because the resistor has to discipate the power).
You need to have clear requirement or else it is all over the place. As I said, it you want high power output, you are going to have to design a custom DC to DC converter and that is hard. Anything here is just speculation.
  • · Replies 47 ·
  • · Replies 28 ·
  • · Replies 31 ·
