| New Reply |
Classical statistical mechanics question |
Share Thread | Thread Tools |
| Jan8-11, 04:18 PM | #1 |
Hello. I read this assertion in a book: if we take at an initial time t_0 a constant density distribution [itex]\rho(p,q,t_0)[/itex]
in phase space, then this implies that \rho wil remain independent of time for all [itex]t>t_0[/itex] because by Liouville's theorem [tex]\frac{\partial\rho}{\partial t}=-\sum(\frac{\partial\rho}{\partial q}\dot{q}+\frac{\partial\rho}{\partial p}\dot{p})=0[/tex] I don't understand this because we take [itex]\frac{\partial\rho}{\partial q}=\frac{\partial\rho}{\partial p}=0[/itex] only at t=t_0 which means that [itex]\frac{\partial\rho}{\partial t}=0[/itex] only at t=t_0 it doesn't mean that [itex]\frac{\partial\rho}{\partial t}=0[/itex] for t>t_0 therefore we can not assert that [itex]\frac{\partial\rho}{\partial q}=0[/itex] and [itex]\frac{\partial\rho}{\partial q}=0[/itex] for [itex]t>t_0[/itex] |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb21-11, 10:53 AM | #2 |
I just happened across this post and thought I'd respond (though its a bit late). Why do you take the partials of rho to be zero, as they are not necessarily. Liouville's theorem says that density is constant in time, not in space (over q's and p's)
| Feb21-11, 11:55 AM | #3 |
Yes, a uniform distribution would correspond to the high-temperature Botlzmann distribution. Such a distribution is stationary.
You can use analyticity and induction to prove this. As you say only [tex]\dot{\rho}(t_0) = 0[/tex] immediately follows. Therefore at an infinitesimal time later you have [tex]\rho(t_0+dt) = \rho(t_0) + dt \dot{\rho}(t_0) = \rho(t_0)[/tex]. You can probably see the rest. |
| Feb21-11, 05:00 PM | #4 |
| Feb21-11, 06:38 PM | #5 |
| Feb21-11, 06:51 PM | #6 |
By constant in time I meant that the total derivative [tex] d\rho/dt = 0 [/tex]. But the partials with respect to position need not be, that is: [tex] \partial \rho / \partial q \neq 0 [/tex], ditto with respect to momenta. Are you asking for a proof of the theorem? Many books don't really prove the theorem but sort of wave their hands and throw up a continuity equation for the density.
| Feb21-11, 07:14 PM | #7 |
You have a 1st order partial differential equation for the function rho (the velocities can be written in terms of the coordinates through derivatives of the Hamiltonian).
What is the boundary condition for a 1st order partial differential equation? The answer is values of the function on the hypersurface. You are given the values on the hypersurface t=0. So that should be enough to determine the solution completely. Hence rho=constant is the solution for all time and all phase space. Now there's always the question whether these Cauchy conditions are too much and no solution exists (for 1st order differential equation the Cauchy conditions will be just the value of the function on a hypersurface). However, for this problem you don't have that problem, since rho=constant is obviously a solution. So rho=constant is the only solution that satisfies the boundary conditions and the differential equation. |
| Feb21-11, 11:00 PM | #8 |
| Feb22-11, 04:45 AM | #9 |
| Feb22-11, 04:51 AM | #10 |
| Feb22-11, 05:21 AM | #11 |
Consider this, rho is constant along a trayectory in phase space and that's what Liouville's theorem is all about. However this doen not mean that if you fix your position in phase space and let the time flow rho will remain constant, neither it means that if you freeze time at same instant t and wonder arround phase space rho wil remain constant as you move. I think the argument given by RedX could be correct |
| New Reply |
| Thread Tools | |
Similar Threads for: Classical statistical mechanics question
| Classical Thermodynamics for Statistical Mechanics | Classical Physics | 2 | ||
| Statistical mechanics question - please help | Advanced Physics Homework | 0 | ||
| classical statistical mechanics: dimensions of partition function | Classical Physics | 2 | ||
| [SOLVED] Is Classical Statistical Mechanics dead? | General Physics | 18 | ||
