Are any of the topologies metrizable?
  • Thread starter Thread starter tylerc1991
The discussion revolves around the question of whether specific topologies defined on a finite set X = {1,2,3} are metrizable. The topologies in question include T1 through T7, each with distinct open sets.
  • The original poster attempts to determine which topologies can be expressed as unions of open balls, considering the concept of a discrete metric. Some participants inquire about the T1-axiom and its implications for metrizability, while others question the metrizability of T0, T1, and T2 spaces.
Participants are exploring the relationships between the properties of the topologies and their metrizability. Some guidance has been provided regarding the implications of being T0 or T1 on metrizability, and there is an ongoing examination of the characteristics of the given topologies.
There is a focus on the definitions and properties of the topologies, particularly in relation to the T1-axiom and the conditions under which a finite space is metrizable. The discussion reflects uncertainty regarding the specific classifications of the topologies presented.
tylerc1991
Given a set X = {1,2,3} and the following topologies:
T1={{1}, empty set, X}
T2={{1}, {2}, {1,2}, empty set, X}
T3={{1,2}, {2,3}, {2}, empty set, X}
T4={{1}, {2}, {1,2}, {2,3}, empty set, X}
T5={{1,2}, empty set, X}
T6={{1}, {2,3}, empty set, X}
T7={{1}, {1,2}, empty set, X}
Are any of the topologies metrizable? Explain.
So I started by looking for the subsets that could be realized as the union of open balls. I was picturing a 'discrete metric' type scenario where each point is itself an open ball of r<1. In that case it looks like T5 contains the only subset that can be expressed as the union of open balls (the open balls being a ball around 1 and 2). Any help is definitely appreciated.
Do you know what the T1-axiom is? And do you know that every metrizable space is T1?
OK that definitely led me on the right track in determining what type of spaces the various topologies are, but now I have a new question: is a T0-space metrizable? (or a T1-space or T2-space for that matter?) Thanks again for your help.
No, a T0-space is in general not metrizable. However, the converse holds: if a space is metrizable, then it is T0. So if you find that your space is not T0, then it cannot be metrizable.
The exact same thing holds with T1, T2, T3, T4, T5 and T6...
So, since none of your spaces is T1, they cannot be metrizable.
In fact: a finite space is metrizable if and only if it is discrete...
  • · Replies 58 ·
