Quick questions about logic gates (Nand, nor, etc)
  • Thread starter Thread starter Molecular
    Logic Logic gates
This discussion focuses on the functionality and configuration of NAND gates, specifically the role of NMOS and PMOS transistors. The two NMOS transistors in a NAND gate configuration serve to pull the output low when both inputs A and B are high, effectively removing voltage from the output. PMOS transistors are typically used at the top of the configuration due to their ability to handle higher voltages and avoid voltage drops when A or B signals are high, despite NMOS transistors being faster. Additionally, the feasibility of creating a single-transistor AND gate with two separate gate elements is explored.
  • Understanding of NAND gate configurations
  • Knowledge of PMOS and NMOS transistor characteristics
  • Familiarity with digital logic design principles
  • Basic concepts of voltage levels in logic circuits
  • Research the operation of NMOS and PMOS transistors in digital circuits
  • Learn about the design and implementation of NAND gates
  • Explore the concept of single-transistor logic gates
  • Investigate voltage drop issues in logic gate configurations
Electronics enthusiasts, digital circuit designers, students studying logic design, and anyone interested in the practical applications of logic gates.
Molecular
So recently just in my spare times I've found an interest in logic gates such as the nand gates and nor gates and such and although most of it's logic, there's one thing i just couldn't figure out.
Let's say you have a nand gate configuration consisting of two pmos and two nmos transistors as in my attached picture, what exactly is the purpose of the two nmos transistors at the bottom? I'm guessing it's related to removing any voltage on the output as soon as A and B go high.
Another question I have though; Why is usually pmos transistors used at the top? If I'm not entirely mistaken, aren't nmos transistors supposed to be faster? Or is this to avoid a voltage drop when your A or B signals are high?
And finally thirdly, would it be possible to create a transistor with two separate gate elements in which both needs to be set high in order to allow for current to go through? A single-transistor and-gate in other words.
Thanks for any input on this! been scratching my head.
  • · Replies 23 ·
  • · Replies 29 ·
