Easy trig prob what did I do wrong?
  • Thread starter Thread starter Miike012
    Trig
The problem involves finding the angle in degrees subtended at the center of a circle by an arc whose length is 357 times the radius, with a specific value for pi provided. Participants are exploring the implications of this setup and the calculations involved.
  • Participants discuss the original poster's calculations and the interpretation of the arc length relative to the circle's circumference. There are questions about the correctness of the original interpretation and the calculations leading to the angle in degrees.
Some participants are questioning the assumptions made in the problem, particularly regarding the arc length being significantly larger than the circumference of the circle. Others suggest that the problem may have been misinterpreted, indicating a possible misunderstanding of the relationship between the arc length and the radius.
There is a suggestion that the problem might have intended for the arc length to be 0.357 times the radius instead of 357 times, which could change the interpretation and calculations significantly. Participants are also discussing the conversion between radians and degrees and the meaning of specific mathematical symbols used in the context.
Miike012
Find number of deg. subtendedat the center of a circle by an arc whose length is 357 times the radius,taking pi = 3.1416...
The arc length is... 357(r)
The radius length is r
One revolution = 2r(pi) = arc lenght.
Now I will solve...
2r(pi)x = 357(r)
x = 357/2(pi)
(360 deg = 2r(pi))(357/2(pi))
357(r) = 20454.5 deg.
In the back of the book it says...20.4545
As you can see I am off a couple decimals... what happened?
The book failed, that's what happened.
20o is tiny. It's obviously wrong :wink:
So are you saying I am correct?
Yes that's exactly what I'm saying.
By the way, just remember that [tex]\pi \equiv 180^o[/tex] so [tex]357 = 357\cdot\frac{\pi}{\pi} = 357\cdot \frac{180^o}{\pi}=20454^o[/tex]
It looks like you took the arc and mult by a rad and that gave you deg?
I thought you could only take rad and convert it to deg.
What does the triple line between the pi and 180 sign mean?
The entire circumference is only [itex]2\pi= 6.18...[/itex] times the radius so an arc that is "357 times the radius" is far more than a single entire circle. Since the idea of an arc looping back on itself is peculiar, I suspect that the problem should have been to "find an angle so that the are is 0.357 times the radius". That would give
[tex]\frac{\theta}{180}= \frac{0.357}{\pi}[/tex]
so that [itex]\theta= 20.45[/itex] degrees.
Oh right, that might certainly be what it was looking for. I guess I misinterpreted the question just like the OP did.
It means they're equivalent. Just think of it as equals for the moment because it doesn't have many big differences.
The arc is measures in radians and you can convert between radians and degrees freely.
  • · Replies 21 ·
  • · Replies 87 ·
  • · Replies 17 ·
