Waves & Sound: Combine Pressure & Density to Produce Dimensions of Speed
The discussion revolves around the relationship between pressure and density in air, specifically how these quantities can be combined to derive dimensions of speed, particularly in the context of sound waves. The original poster expresses confusion regarding the application of wave speed equations to sound, which is not a wave on a string.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the fundamental dimensions of pressure and density, questioning how to combine them to yield dimensions of speed. There is a focus on manipulating the equations for pressure and density to eliminate mass and derive a speed-related expression.
Some participants have offered insights into the dimensional analysis of pressure and density, suggesting that combining them could lead to a speed expression. There is acknowledgment of the original poster's analogy with wave speed in strings, and a productive direction is noted in the exploration of the expression for speed as the square root of pressure over density.
Participants are working within the constraints of deriving a relationship without providing complete solutions, and there is an emphasis on understanding the underlying principles of wave mechanics as they relate to sound.
sammmy
Two important quantities associated with air are the pressure and density. How can the pressure and density be combined to produce dimensions of speed? Look up the pressure and density of air at sea level and use your equation to estimate the speed of sound. Is your answer reasonable?
pressure (P)= force/area
area of sphere= 4[tex]\Pi[/tex]d[tex]^{2}[/tex]
density (p)= mass/volume
somehow I'm assuming you're supposed to use the equation for the speed of a wave that includes force, which is V=[tex]\sqrt{T/\mu}[/tex]
but T=tension of the string. Since sound is not a wave on a string.. i am thoroughly confused.
Welcome to PF sammmy!
I think the first thing would be to write out the fundamental dimensions of each quantity:
I'll use [L] to mean "length", [M] for mass, and [T] for time:
[tex][P] = \frac{[F]}{[A]} = \left([M] \cdot \frac{[L]}{[T]^2}\right)\left(\frac{1}{[L]^2}\right)[/tex]
in the last part on the right hand side, the quantity in the first set of parentheses is force (mass*acceleration), and the quantity in the second set of parentheses is 1/area.
So, pressure reduces to dimensions of:
[tex][P] = \frac{[M]}{[L][T]^2}[/tex]
similarly for density:
[tex][\rho] = \frac{[M]}{[V]} = \frac{[M]}{[L]^3}[/tex]
Now, does anything jump out at you? Hint: you want to get rid of [M] entirely.
Well, since dimensions of speed are meters/second- It seems as if the density equation would need to be flipped to 1/[tex]\rho[/tex] which is equal to L[tex]^{3}[/tex]/M so the masses cancel out
but I'm not sure how you can equate pressure and density.. ?
You can't "equate" them. But you can combine them together algebraically in an expression, in such a way that you are left with something that has dimensions of [L]/[T] (speed).
how about..
[tex]\sqrt{P/\rho}[/tex] so that [tex]\sqrt{(M/LT^{2})/(M/L^{3})}[/tex] which equals L/T
sammmy said:
how about..
Yes. Good work.
EDIT: Sound is indeed a wave, and you could have derived this result from the appropriate wave equation. I bring this up because your attempt in your original post to make an analogy with the wave speed for waves propagating in a string was a good insight. P is sort of analogous to T in its role of "forcing" or driving the oscillations (I think). The mass density appears in both equations and is a sort of "inertial" factor.
cepheid said:
yes. Good work.
Edit: Sound is indeed a wave, and you could have derived this result from the appropriate wave equation. I bring this up because your attempt in your original post to make an analogy with the wave speed for waves propagating in a string was a good insight. P is sort of analogous to t in its role of "forcing" or driving the oscillations (i think). The mass density appears in both equations and is a sort of "inertial" factor.
thank you!
  • · Replies 23 ·
  • · Replies 31 ·
33K
9K
