Curve Sketching: Finding X-Intercepts for 2(x^3)-6(x^2)-18x+7 Equation
  • Thread starter Thread starter Jet1045
    Curve
The discussion revolves around finding the x-intercepts of the polynomial equation 2(x^3) - 6(x^2) - 18x + 7. Participants express difficulty in solving the problem and explore various methods of factoring and analyzing the polynomial.
  • Participants discuss the importance of factoring the entire polynomial rather than isolating x. There is a mention of the Rational Roots Theorem and preliminary analysis to identify potential roots. Some express uncertainty about the correctness of the original problem statement.
The conversation is ongoing, with participants providing insights into different approaches to factor the polynomial. Some have suggested that the roots may be irrational and have shared their experiences with graphing the function. There is no explicit consensus on the method to proceed, but various ideas are being explored.
Participants note that they have not learned many factoring techniques in class, which may limit their ability to solve the problem. There is also a concern about whether the problem was copied correctly, as some suspect the roots may be complicated.
Jet1045
I am finding the x intercepts of 2(x^3)-6(x^2)-18x+7 . For some reason I am NOT getting it, even though its probably really easy.
I set the equation to 0 and then isolated the x's and got
-7 = 2(x^3)-6(x^2)-18x
factored out a 2x and got
-7 = 2x((x^2)-3x-9)
i tried factoring (x^2)-3x-9 and have no idea how.
can someone please explain where to go from here and how to find the zeroes, or if there is another way to do so
well, factorizing by isolating the x's will not help at all. You should factorize the entire expression, i.e.
try and factorize 2 x^3 - 6 x^2 - 18 x+7.
The reason your method won't help is the following:
if i have an expression of the form (x-a)(x-b) = 7, given that x is any real number, I cannot conclude anything useful about x. But if the expression was
(x-a)(x-b) = 0, I can safely say that x = a or x = b.
Thanks very much for the help, i didn't realize that by bring the 7 over I would have that problem, I am so used to just trying to isolate x's lol
so i tried factoring the whole equation with the 7 on that side , with NO luck :(
any ideas. We have not learned to many factoring techniques in class.
You want to completely factor your polynomial expression. You might be able to find up to three places where the polynomial equals zero.
well, u can do some preliminary analysis to remove out some possibilites - the solution is definitely not an integer (can you guess why?)
but, I have a doubt about whether you have copied your question down correctly? this seems to have rather complicated roots.
Maybe the exercise was intended for solution method including Rational Roots Theorem.
Well after graphing it on my calculator, I know that there are in fact 3 roots, and they are very long decimals.
i guess there is a chance that I remember the question wrong. hopefully when I get back in class tomorrow it is a lot easier :(
The idea about the Rational Roots Theorem is that you can try various combinations of rational numbers using the leading coefficient and the constant term from the polynomial, and try dividing the polynomial by a binomial which uses the various rational numbers; and if a division renders a quotient with remainder of zero, you have found a root. You continue looking for other binomial factors this way until you have factored your original polynomial as much as possible.
Are you sure your graph is showing irrational zeros, or are the zeros actually nonrepeating decimals just maybe long?
UPDATE: I used polynomial division to check for the possible eight rational zeros, and all of them gave remainders, meaning the tested roots failed as actual roots for the given polynomial. You must be correct in having irrational roots, whatever they be.
The roots are irrational when i checked my calculator...
i have no idea how , i don't think the rational roots theorem is what he is looking for because we have never done that in class.
i am PRAYING that i copied it down wrong haha
thanks for your help! :)
  • · Replies 24 ·
