Wave Theory Questions & Answers
  • Context: Graduate
  • Thread starter Thread starter pinsky
    Theory Wave
This discussion focuses on wave theory, specifically the mathematical calculations of wave equations for strings with fixed and loose ends. The wave equation for a string fixed at one end is expressed as u_0 Sin(ωt - kx) = -u_0' Sin(ωt + kx + φ). It is established that at a loose end, the string must have a maximum amplitude due to boundary conditions, which require the tangent to be horizontal to avoid vertical force components. Additionally, the discussion addresses the conditions under which a string resonates when subjected to an impulse, emphasizing that the harmonic level of resonance is determined by the string's physical properties and boundary conditions.
  • Understanding of wave equations and harmonic motion
  • Familiarity with boundary conditions in physics
  • Knowledge of string tension and its effects on oscillation
  • Basic mathematical skills for solving trigonometric equations
  • Study the derivation of the wave equation for strings with fixed and loose ends
  • Explore the concept of boundary conditions in wave mechanics
  • Investigate the principles of resonance in physical systems
  • Learn about the effects of tension and length on harmonic frequencies of strings
Students and educators in physics, particularly those focusing on wave mechanics, as well as engineers and researchers involved in acoustics and material science.
pinsky
Hello there.
Can someone pleas shed lite on some of these questions.
How does one mathematically calculate (wave equation of a string that has one end tied on a unmoveable wall. The second wave is after reflecting from the wall) the first wave is known to us (u0 omega and k)
[tex]u_0 \; Sin(\omega t - kx)=- u_0' \; Sin(\omega t + kx + \phi)[/tex]
Conditions for a wave on a string which has a lose end. Why does that point has to always have a maximum amplitude when the string is oscillating?
When we apply a short impulse (force*time) on a string which is attached between two unmovable walls, does it always start to resonate? What determines the harmonic level of the resonation?
have a nice day
pinsky said:
Hello there.
Because of your boundary condition the tangent to the string at the loose end have to be horizontal otherwise you would have a vertical component of force owed to the string tension
  • · Replies 16 ·
  • · Replies 0 ·
  • · Replies 34 ·
