What is the Differentiation Rule for an Oven Temperature Function?
  • Context: Undergrad
  • Thread starter Thread starter cowgiljl
    Differentiation
The differentiation rule for the oven temperature function, represented by f(t) = (400t + 70)/(t + 1), was analyzed using the quotient rule. The derivative, f'(t) = 330/(t + 1)^2, indicates the rate of change in temperature over time. At t = 2 minutes, the temperature increases at a rate of 36.67°F per minute, while at t = 10 minutes, the rate drops to 2.73°F per minute. The discussion also clarified that for the oven to reach 350°F, the correct time is not 5 minutes, as previously suggested.
  • Understanding of calculus, specifically the quotient rule for differentiation
  • Familiarity with functions and their derivatives
  • Basic knowledge of temperature measurement in Fahrenheit
  • Ability to solve algebraic equations
  • Study the application of the quotient rule in calculus
  • Explore the implications of derivatives in real-world scenarios, such as temperature changes
  • Learn how to analyze functions for critical points and behavior over intervals
  • Investigate temperature modeling in physics and engineering contexts
Students studying calculus, educators teaching differentiation, and professionals in fields requiring temperature modeling and analysis.
cowgiljl
f(t) = 400t+70/t+1 represents the temp. in an oven and f(t) is in F degrees
first i used the quotient rule and got 330/(t+1)^2 = f'(t)
A) the rate of change in temp of the ove with respect to the time of 2 minutes after turnig the oven on and at 10 minutes
i pluged 2 and 10 in for t in the equation above
330/(2+1)^2 = = 36.67 F degrees per min
330/(10+1)^2 == 2.73 F degrees per min
B) fined the rate of change of temp when the oven is 350 degrees
i plugged in 350 where f(t) is
and got t = 5 min
thanks joe
Hmm. That's odd. I get a different answer for [tex]f'(t)[/tex]. You might want to check your work. (Even if I use [tex]f(t)=400t + \frac{70}{t+1}[/tex] rather than [tex]f(t)=400t + \frac{70}{t} + 1[/tex].)
For part B:
[tex]f(5)=400 \times 5 + \frac{70}{5} + 1=2000+12+1=2013[/tex]
So, clearly t=5 is not the correct time.
I guess he was saying f(t)=(400t+70)/(t+1)
  • · Replies 36 ·
  • · Replies 0 ·
