Proving Continuity of Real-Valued Functions Using G_delta Sets
  • Thread starter Thread starter fourier jr
    Sets
The discussion revolves around proving that the set of points at which a real-valued function is continuous forms a G_delta set. The participants are exploring the topological definition of continuity and its implications in the context of real analysis.
  • Participants discuss using the topological definition of continuity and the concept of intersecting open sets to characterize continuity. There are suggestions to consider weaker conditions that approach full continuity through a sequence of sets.
The discussion is active, with participants sharing insights and hints about approaching the problem. Some guidance has been offered regarding the use of neighborhoods and the nature of G_delta sets, indicating a productive exploration of the topic.
There is mention of a specific problem from a textbook, and participants reference their coursework, which may imply constraints related to their current studies in real analysis.
fourier jr
"Let f be a real-valued function defined for all real numbers. Prove that the set of points at which f is continuous is a [tex]G_\delta[/tex]."
(a set is a [tex]G_\delta[/tex] if it is the intersection of a countable collection of open sets)
I think it's obvious that I should use the topological/open-set definition of continuous, and then intersect a bunch of open sets but I'm not sure how to write it down. (if that makes any sense)
Ahh, question 53 from Royden..taking math 435? (I went to UVic years ago).
f is continuous at a point if for every epsilon there is a delta..blah blah, you know the rest. For a hint, try to make the "for every" part handled by the intersection of your sets, that is take your sequence of sets to characterize the points were f satisfies a weaker condition than full blown continuity, but one that is getting "closer" to the full definition as you move along your sequence of sets.
Well, in topology you're going to want to take unions, not intersections of open sets. That said, I think you'll be better off if you work with neighborhoods rather than abstract topology definitions.
Hrm, I spent a couple minutes thinking about the problem, and came up with the same approach as shmoe, so it must be right. :biggrin:
Nate, since he's after an element of [itex]G_{\delta}[/itex], and not an open set, it's okay to intersect his open sets. In fact, the theorem couldn't be true using just open sets, because there are functions continuous at exactly one point!
shmoe said:
..taking math 435?
yup... can't wait to get to the riesz-fischer theorem & related stuff (because I'm Fourier jr)
thanks for the tips everybody; i think it worked out ok. :smile:
