Is op amp or any amplifier circuit/device a over-unity device?
The discussion revolves around the concept of whether operational amplifiers (op amps) or any amplifier circuit/device can be classified as over-unity efficient devices. Participants explore the definitions of efficiency, voltage gain, and the relationship between input and output power in the context of amplifiers.
  • One participant questions if op amps can be considered over-unity devices, noting that Vout is greater than Vin, leading to confusion about power input and output.
  • Another participant clarifies that over-unity efficiency would imply over 100% efficiency, which they assert is not possible, expressing a desire for such a device if it existed.
  • There is a discussion about how to calculate efficiency, with one participant suggesting that it should not be based solely on voltage gain.
  • Another participant defines efficiency as power out divided by power in, emphasizing that power input includes both driving power and power from supplies, and expresses confusion regarding the calculation of efficiency for amplifiers.
  • Concerns are raised about the relationship between voltage and power, with a participant noting that high voltage gain may not correlate with high output current, drawing a comparison to transformers.
  • A later reply reiterates the initial question about over-unity efficiency and asserts that there is no free energy, suggesting that the energy for amplifiers comes from external power sources.
Participants do not reach a consensus on the definition of efficiency or the classification of amplifiers as over-unity devices. Multiple competing views and uncertainties remain regarding the calculations and implications of efficiency in amplifier circuits.
Limitations in the discussion include varying definitions of efficiency, the dependence on specific contexts for power calculations, and unresolved questions about the relationship between voltage gain and output current in amplifiers.
Pagedown
Is op amp or any amplifier circuit/device a over-unity efficient device?
The above question has been stuck in my mind, and I can't figure it out, as Vout is greater than Vin which Pin>Pout. So is it?
I heard a lot about free energy and aether, thus come to this question.
Do you mean over 100% efficiency? Absolutely not. If there is one, I want one too!:smile:
Or are you just talking about voltage gain?
the efficiency. So how to calculate its efficiency, if it is not Vout/Vin since it is voltage gain?
I am confuse how do you define efficiency? I am confused. To me, efficiency means power out divid by power in times 100 percent. Nothing even come close to 100%. Power in include the driving power plus the power input from the power supplies.
So power in should be the Voltage IN while power out should be Voltage OUT? I am confused how to calculate it. Maybe although the voltage gain is high, the output current is very low? I do know that is true for transformers, but don't know for any opamp or semiconductor.
I will put this as gently as I can.
The big giant battery or the wall power plug is where the "extra" energy comes from for power amplifiers. There is no free energy.
Thread closed. Please re-read the Rules link at the top of the page that you agreed to when you joined our forums.
Just to add one thing: voltage is not power. Wattage is power.
