How much work is required to drink through a straw placed in a glass of water?
  • Context: Undergrad
  • Thread starter Thread starter Alem2000
    Computing Work
The discussion revolves around calculating the work required to drink water through a straw placed in a glass. Participants explore the physics of lifting water, focusing on the integration of forces and the application of work-energy principles. The conversation includes various approaches to the problem, including the use of different variables and integration techniques.
  • One participant describes the setup of the problem, detailing the dimensions of the glass and the straw, and expresses confusion over unit conversions and height definitions.
  • Another participant suggests considering a thin layer of water and questions the addition of a height term in the work equation.
  • A different approach is proposed, defining a slice of water and integrating the work needed to lift each slice to a specified height.
  • Participants discuss the importance of consistent variable definitions, particularly regarding the height of the fluid and the variable of integration.
  • One participant recalculates the work using a different height term and presents a new integral, seeking confirmation on the correctness of their approach.
  • Another participant emphasizes the need to minimize arithmetic errors by delaying numerical substitutions until the final steps of calculations.
  • One participant confirms the correctness of a calculation presented by another, indicating some level of agreement on that specific approach.
Participants express differing methods and interpretations of the problem, leading to multiple competing views on how to approach the calculation of work. There is no consensus on a single correct method or final answer, as participants continue to refine their approaches and challenge each other's reasoning.
There are unresolved issues regarding the definitions of variables, particularly the use of "h" as both a constant and a variable. Additionally, participants have not fully clarified the assumptions behind their calculations, such as the treatment of the height of the water and the straw.
This discussion may be useful for students and enthusiasts interested in physics problems related to fluid dynamics, work-energy principles, and integration techniques in mathematical physics.
Alem2000
Can someone tell me what I am doing wrong? "A glass is a cylinder, 15cm tall and with a radius of 3cm. It is filled 12.5cm high with water d=1000kg/m^3.
A straw is placed in the glass, with the top of the straw 5cm above the top of the glass. How much work does it take to drink through the straw? Note..for the purpose of computing work, it is safe to assume that you are always drinking from the top most "layer" of water, no matter where the straw is placed."
I started using a system that the bottom of the cup is 0 height..and the top of the cup 15...I think some people do it the other way around :confused:
By the way I converted from cm to m randomly in the problem whenever the units came up in the problem.
This is my work...
[tex]\vec{W}=\vec{F}d[/tex]
[tex]\vec{F}=m\vec{a}[/tex]
[tex]d=m/V[/tex]
[tex]d=1,000kg/m^3[/tex]
[tex]V=9\pi,cm^2[/tex]
using the equations form above [tex]m=.9\pi,kg/m[/tex]
[tex]\vec{F}=\vec{w}=8.82N\pi[/tex]...weight
[tex]\vec{W}=(8.82)(h+.05)J\pi[/tex]..work
[tex]\vec{W}=8.82h=.441)J\pi[/tex]
[tex]\pi\int_{0}^{.125}8.82h+.441dh[/tex]
so far so good?
after integrating...i said that it takes [tex]2182.1J[/tex] to do the work I am assuming that's wrong...thats a lot of Joules just to drink some water ay?
Imagine a thin (thickness dx) "layer" of water a height x (meters) above the base. That layer is a disk of radius 0.03 m in radius so its volume is 0.0009πdx cubic meters and so its mass is .9 πdx kg and its weight is 8.829 π dx Newtons.
That appears to be what you have but then you say
Where is that "+ 05" from?
That layer has to be lifted a distance .15- x meters which requires work of
8.82π(0.15- x) dx Joules. The total is the integral of that as x goes from 0 to 0.15.
I have a hard time understanding what you did. Try it this way. First define a slice of water of thickness "dy". Its mass is [itex]dm = \rho \pi r^2 dy[/itex]. The amount of work you need to do to lift each slice from its position y to the final height of h = .2 m is [itex]dW = g(h - y)dm = \rho \pi r^2 g(h - y)dy[/itex]. Integrate this from y = 0, 0.125m.
Okay let me try again from mass, [tex]m=.9h,kg\pi[/tex] and then i plug
that into [tex]\vec{F}=m\vec{a}[/tex] and [tex]\vec{a}=9.8m/s^2[/tex] get [tex]\vec{F}=8.82h,N\pi[/tex]
so then I plug that into [tex]\vec{W}=\vec{F}d[/tex] which would give me
[tex]\vec{W}=(8.82h)(.20-h)J\pi[/tex]... I used this [tex].20-h[/tex] because
the drink is going to be moving through the straw which is .05m above the top
of the glass(top of glass=.15m) and then to find the work I
[tex]\pi\int_{0}^{.125}(8.82h)(.20-h)dh[/tex] and this time I got
[tex].0252554597J[/tex]...how does that look I think the only place we got
different results is the the height. So is this correct? And would
[tex].05+x[/tex] be okay?
Again, it is difficult to follow what you are doing. It seems you are using "h" both as a constant (the height of the fluid?) and as your variable of integration. See my previous post and see if you can follow what I did.
Also, most of the time it's easier if you wait until the last minute before plugging in numbers and grinding out the arithmetic. That also minimizes errors.
[tex]m=(.0009mdhm^3)(1000kg/m^3)[/tex]
[tex]\vec{F}=(.9dhkg\pi)(9.8m/s^2)[/tex]
[tex]\vec{W}=(8.82dhN\pi)(.20m-h)[/tex]
[tex]\pi\int_{0}^{.125}(8.82)(.20-h)dhJ[/tex]
And then integrate away? Is that correct? I got [tex].476J[/tex]
Looks right to me.
9K
9K
