How do I apply the product and chain rule to this equation?
  • Thread starter Thread starter Spectre32
    Chain
The discussion revolves around applying the product and chain rule to the equation dw/dt = w = r^2 - s*tan(v), where r, s, and v are defined in terms of t. Participants are exploring how to differentiate this expression correctly.
  • Mixed
  • Participants are questioning the correct interpretation of the equation and whether to differentiate all components simultaneously or individually. There is confusion regarding the notation and the expression for w.
The discussion is ongoing, with some participants providing guidance on using the product and chain rule. There is a recognition of the need to clarify notation and ensure all variables are expressed in terms of t.
There is some confusion regarding the notation used in the problem, particularly concerning the expression for w and the presence of 'x's. Participants are emphasizing that all derivatives must be taken with respect to t.
Spectre32
OK I have this problem
Code:
dw/dt = w = r^2-s*tan(v)
And it gives the following:
Code:
r = sin^2(t)  s = cos(t) v = 4t
Soo...now Do i derive those still with respect to all those values? Or can i knock them all out in a line or two.
i don't quite understand how dw/dt = w
perhaps you have made an error in your code
No it's right... I think it's just saying that They want your answer to be liek
W = 'xxxxxxx'
It is incorrect; period.
the only functions satisfying dw/dt=w is w(t)=Ke^t for some K.
This does NOT agree with the last equality.
Hmmm whoops... this is how the problem reads: Find dw/dt if
w = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'
Count the number of x's you've got, then UNLEASH the chain rule.
... There are no X's in that problem. As i said is it best to go through and derive them all at once or so i got to like derive and multiply what each value holds. Everything Must be in terms of t
Please be more careful in your notatiton!
You wrote:
"w = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx'"
I know what you meant, now; you should have explicitly written that this was a substitute for the expression given in post 1.
w = r^2-s*tan(v)
You know what each part is in terms of t...that is what everyone is saying...now just bust out the product and chain rule...you hsould get the answer
we almost have the same name...
  • · Replies 21 ·
