Is My Approach to Simplifying Complex Fractions Correct?
  • Context: High School
  • Thread starter Thread starter JasonRox
    Complex Textbook
The discussion revolves around the simplification of complex fractions and the calculation of moduli for complex numbers. Participants explore different methods for finding the modulus of complex expressions and clarify their approaches to division involving complex numbers.
  • One participant proposes a method for finding the modulus of (2-i)^6, suggesting it equals |2-i|^6, but questions arise about the correctness of this approach.
  • Another participant challenges the simplification of a complex fraction, stating that the numerator and denominator cannot be equal if they are different.
  • There are discussions about the correct application of the formula for dividing complex numbers, with some participants correcting each other's expressions.
  • Participants express confusion over the treatment of the variable 't' in their calculations, with some asserting that it cannot be disregarded when finding the modulus.
  • One participant attempts to clarify the modulus of a complex fraction, leading to a discussion about the conditions under which the modulus can be calculated.
  • Another participant emphasizes the importance of stating assumptions, such as whether 't' is a real number, to avoid confusion in the calculations.
There is no consensus on the correct method for simplifying the complex fractions or calculating the moduli, as participants present differing views and corrections throughout the discussion.
Some participants express uncertainty about the assumptions made in their calculations, particularly regarding the nature of 't' and the conditions under which the modulus is calculated. There are also unresolved mathematical steps that lead to different interpretations of the results.
This discussion may be useful for students or individuals interested in complex numbers, particularly those looking to understand the nuances of simplifying complex fractions and calculating their moduli.
JasonRox
I want to make sure I am on the right track here.
Here is the first one:
Find the modulus of:
[tex](2-i)^6=|2-i|^6=(\sqrt{5})^6=125[/tex]
Am I doing it right?
I broke it up at first, but then the book says this. The answers are different, or what I got was different.
The second:
[tex]\frac{1+2ti-t^2}{1+t^2}=1[/tex]
Work the bottom and you can get:
[tex](1+t^2)=(t+i)(t-i)=(ti+1)(1-ti)[/tex]
Work the top:
[tex](ti+1)^2[/tex]
I can only eliminate one of the two on the bottom.
I went on with division, and then I got to 1.
Is that ok?
The first one looks good but what exactly are you trying to do with the second?
"I can only eliminate one of the two on the bottom."
Yes, that leaves the fraction (1-ti)/(1+ ti).
"I went on with division, and then I got to 1.
Is that ok?"
No, it's not! Since the numerator and denominator are different, the fraction CAN'T be 1! HOW did you "go on with division"?
It's something like,
[tex]\frac{(ac-bd)+(ad-bc)i}{a^2+b^2}[/tex].
That's division for complex numbers.
Isn't that right? That came to i, and then the modulus of i is 1? Right?
It's, unclear what you're trying to do with the second one, or at least i though iknew you were solving for t, albeit in some odd way (why not just mutlply by 1+t^2 and solve the resulting quadratic? it's just an equation after all) but I've no idea what the modulus of i being 1 has to do with it.
No, that's wrong
[tex]\frac{a+bi}{c+di}= \frac{(ac+bd)+(ad-bc)i}{a^2+b^2}[/tex]
Notice that it is "ac+bd", not "ac- bd" as you have.
What you are really doing is multiplying both numerator and denominator by c- di, the "complex conjugate" of c+ di.
The numerator is (a+ bi)(c- di)= ac+ adi- bci- bdi2
= (ac+ bd)+ (ad-bc)i
while the denominator is (c2+ d2).
In particular,
[tex]\frac{1-ti}{1+ti}= \frac{(1-t^2)- 2it}{1+t^2}[/tex]
Sorry, honest mistake there.
I did the division that the book showed and it came out to one. Also note that (1-ti) is the denominator.
Note: I am trying to find the modulus, so that's why I got 1 from i. So, lil=1.
This is what it comes out to:
[tex]\frac{1+ti}{1-ti}=\frac{(1)(1)+(-1)(1)+i[(1)(-1)-(1)(1)]}{1+1}[/tex]
and so it equals -i.
l-il=1, as well.
Is this right?
So I guess it's ok.
l-il=1, as well.
Is this right?
What happened to the "t"??
[tex]\frac{1+ti}{1-ti}= \frac{(1+ti)(1+ti)}{(1-ti)(1+ti)}= \frac{(1-t^2)+ 2ti}{1+t^2}[/tex]
That depends upon t and so does its modulus.
You can't just replace "i" by 1 because |i|= 1 . |1+ i| is NOT equal to
1+ 1 just as |1- 3| is NOT 1+ 3.
Damn. I really messed up.
I got:
[tex]\frac{1+2it-t^2}{1+t^2}[/tex]
Which is the same, and that's good now.
I still can't find a path that leads to a modulus of one.
Note: I appreciate the help.
Jason - I think your method of doing the first one; "find the modulus of (2-i)^6 is incorrect. I think what the problem asks you is to raise the complex number (2-i) to the 6th power and then find the modulus of that complex number - not raise the modulus of (2-i) to the 6th power.
But |(2 - i)^6| is equal to |2 - i|^6... He probably forgot to write out the vertical lines.
No, vertical lines.
Geometer, that is EXACTLY what I did. See the part where I said I broke it apart, and the answer was different. I'll do it again, but who knows.
I have the same problem. You cannot just drop 't' out of the equation this way.
I understand that, but that doesn't show that the modulus equals one.
Have you even written down what the modulus of
[tex]\frac{(1-t^2)+ 2ti}{1+t^2}[/tex]
is?
When you posted this question you didn't even state you were attempting to show it had modulus 1. We aren't psychic! Nor did you state t was a real parameter. In fact you just had an equation with no hint as to what we were supposed to make of it.
The moduls (also "absolute value") of a+ bi is
[tex]\sqrt{a^2+ b^2}[/tex].
In particular, the modulus of (1- t2)+ 2t i is
[tex]\sqrt{(1-t^2)^2+ 4t^2}= \sqrt{1- 2t^2+ t^4+ 4t^2}[/tex]
[tex]= \sqrt{1+ 2t^2+ t^4}= \sqrt{(1+ t^2)^2}= 1+t^2.<br /> <br /> Since the denominaotr of [itex]\frac{(1-t^2)+ 2ti}{1+t^2}[/itex] IS the positive real number 1+t<sup>2</sup>, the modulus is 1.<br /> <br /> (That's assuming, of course, that t is a real number, which, as matt grime pointed out, you never did say.)[/tex]
Oh, I wasn't sure you can find the modulus of the numerator on its own. (I believe that is what you are doing.)
Yes, t is real.
I'll be more informative next time.
[tex]\frac{a+ib}{c}=\frac{a}{c}+ \frac{ib}{c}[/tex]
simple algebra.
now find the modulus:
[tex]\sqrt{\frac{a^2}{c^2}+\frac{b^2}{c^2}}[/tex]
pull out the 1/c^2 and what do you have?
if you'd just worked through it and followed your nose you'd've got the right answer.
I get it now even better now!
Thanks, guys.
