Need help with this heat capacity/ideal gas problem.
  • Thread starter Thread starter blehxpo
    Gas Heat
The discussion centers on the behavior of ideal gases and their heat capacities, specifically the equation Cv/R = A + BT + CT², where A, B, and C are constants. The participants clarify that an ideal gas can follow this equation even when volume changes, contradicting the assumption that constant volume is necessary. For the insulated piston scenario, it is established that the final temperature T2 does not equal the initial temperature T1 due to the first law of thermodynamics, which dictates that work done on the gas results in a temperature increase.
  • Understanding of ideal gas laws and behavior
  • Familiarity with heat capacity concepts, specifically Cv
  • Knowledge of thermodynamic principles, particularly the first law of thermodynamics
  • Basic calculus for deriving equations related to gas behavior
  • Review the derivation of the heat capacity equation Cv/R = A + BT + CT²
  • Study the first law of thermodynamics and its implications for insulated systems
  • Learn about the relationship between work done on gases and temperature changes
  • Explore advanced concepts in thermodynamics, such as adiabatic processes
Students and professionals in physics and engineering, particularly those studying thermodynamics, heat transfer, and gas behavior in insulated systems.
blehxpo
For many gases at low densities and pressures (where ideal gas behavior is obtained), Cv/R = A+BT+CT^2 where A, B, C, are all constants, with appropriate temperature units so that the RHS (right hand side) of this equation is dimensionless.
a> How can a gas be both ideal and follow the equation above, at the same time.
b> Such a gas initially at T1 expands slowly in an insulated piston to double its original volume you would like to find the final temperature T2. A friend suggest you may use the follow equation that we derived in class:
(T2/T1) = (V1/V2)^(R/Cv) = (1/2)^(R/Cv)
where Cv is evaluated at T1. What is wrong with your friend's statement? Find the correct equation that should be solved (implicitly) to find T2.
Attempt:
a. I said it has to be at constant V and high temperature. Not what it was asking
b. It said it was an insulated piston? Doesnt that mean that T1=T2?? But I have really no idea how to do it. :/
Thanks for the Helps please.
For (a), it's an ambiguous question, and I'm not exactly sure what kind of answer they want, but the constant volume thing is definitely wrong because an ideal gas is defined by it's equation of state, which includes how the state variables change with volume. It is also unnecessary, since a gas following this equation could be ideal even as volume changes and with temperature not being high.
For (b), an insulated piston will change it's temperature when work is done on it because of the 1st law. Energy needs to be conserved, so when work is done on the gas and heat can't escape, it's temperature increases, so T2 does not equal T1.
To get the right answer to (b), find where the equation they want to use was derived. Then repeat the derivation, but using what you know about the heat capacity in the necessary place.
  • · Replies 32 ·
11K
  • · Replies 60 ·
11K
