With what initial speed does he throw his first ball?
The discussion revolves around a juggler throwing balls vertically and a football kicker's projectile motion. The juggler's problem involves determining the initial speed required for a ball to reach the ceiling and the timing of two balls thrown sequentially. The football kicker's problem focuses on the angles needed to score a field goal from a specific distance.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the mechanical energy theorem to relate initial speed and height for the juggler's first ball. They discuss the timing of the balls' ascent and their positions when passing each other. Questions arise about the correctness of calculations and assumptions regarding motion. For the football kicker's problem, participants are encouraged to share their approaches and equations relating angles, distance, and height.
Some participants have provided calculations and reasoning for the juggler's problem, while others seek confirmation of their methods. There is an ongoing exchange of hints and suggestions, particularly regarding the second problem, indicating a collaborative effort to clarify understanding without reaching a consensus.
Participants express uncertainty about their calculations and the assumptions made in both problems. The discussion includes references to specific equations and hints provided in the original problem statements, which may influence the approaches taken.
mfk_1868
1-Balls thrown by a juggler: A juggler performs in a room whose ceiling is at a height h
above the level of his hands. He throws his first ball vertically upwards so that it just
reaches the ceiling. At the instant when this happens, he throws his second ball upward
with the same initial speed.
(a) With what initial speed does he throw his first ball?
(b) How much time is required for this ball to reach the ceiling?
(c) How long a time after the second ball is thrown do the two balls pass each other?
(d) How far above the juggler’s hands are the balls when they pass each other?
2-A football kicker can give the ball an initial speed of v . Within what two elevation angles
must he kick the ball to score a field goal from a point at a distance L to the front of
goalposts whose horizontal bars is at a height h above the ground?
(Hint use sin^2θ + cos^2θ = 1 to get a relation between 2 tan^2θ and
1/cos^2θ substitute
and then solve the quadratic equation)
1-(a) mechanical energy theorem implies:
Em1=Em2 (1:position of the ball when it leaves the hand of the man
2: when it reaches the ceiling)
(considering the hand the referential level)
Em1= epp + ec
= 0 + 1/2mv^2
Em2= epp + ec
= +mgh + 0
Em1 = Em2
--> 1/2mv^2 = mgh
--> 1/2v^2 = gh
--> v^2 = 2gh (considering g=10 m/s^2)
--> v^2 = 20h
--> v = squared root of (20h) m/s
(b) in this case we have a varied motion for the ball,
before it reaches the cieling it is a decelerated motion,
so the equation is:
z= -1/2gt^2 +vt +v0 ( negative because it's in the opposite way of the mass force
considering an ascending axiz OZ)
z=h
when -gt + v= 0
--> t = -v/g
--> t = -0.1v (s)
(c) when the second ball leaves the hand of the man
its equation is z= -1/2gt^2 +vt +v0
when the first ball leaves the cieling
its equation is z= 1/2gt^2 +vt
they will pass each other when
z=z
-1/2gt^2 +v0 = 1/2gt^2
--> gt^2 = v0
--> t= squared root of (v0/g) (s)
(d) because it is the same initial speed
and considering that the resistance of air is zero.
we can conclude that the balls are = h/2 m (higher than the juggler)
i don't know if it is correct..
i hope that a mentor can correct it to see if there are mistakes :)
for b>
check the sign of t again ...
for c>
is that the total time ? ... ;) u just missed a tiny bit , but rest of the idea is good enough
for d>
i haven't checked the calculations but why be unsure?
can u use the result u got in c?
-- AI
p.S > mfk, what have u tried for question 2? do post ur working because u can be helped better that way ... the question is straightforward and shouldn't be hard basically ...
Before I "correct" anything, I would like to see what mfk_1868 has tried on this problem!
i solved these problems but want to see if i solved correctly
1-)
V/g=t1 V=t1*g 1/2 g*t1^2=h /sqrt {2h/g}=V =>Answer of a)
t1 = v/g /frac{/sqrt {2h/g}} {g}=t1 =>Answer of b)
t2 is the time described at c.
v*t2 - 1/2 g*t2^2 + 1/2 g*t2^2 = h v*t2=h h/v=t2
t2=/frac{h}{/sqrt {2h/g}} =>Answer of c)
h - 1/2 g t2^2 =>Answer of d)
i am not very sure about second problem
mfk,
whatever u have done with question 2 .. be it wrong or right ..
do post it ... that way u get ur doubts cleared better ...
Some initial hints :
1> forget the hint the question has given for now
2> Can u come up with a equation that relates the elevation angle (say theta) , L and h?
-- AI
i ll post the second question soon but is my first question true?
mfk,
well i could not understand much of your last post
but if u have done the same thing A_I_ has done then u are on the right track ...
i gave a few corrections to his solutions in my last post
-- AI
thanks i ll compare the solutions
  • · Replies 38 ·
  • · Replies 32 ·
  • · Replies 17 ·
