| New Reply |
Do Irreducibles Induce Algebraic Extensions? |
Share Thread | Thread Tools |
| Jan29-11, 07:43 PM | #1 |
Given [tex]K[/tex] a field, and [tex] f\in K[x][/tex] an irreducible (monic) polynomial. Does it follow that the field [tex] K[x]/\left<f\right>[/tex] is an algebraic extension of [tex]K[/tex]?
| Jan29-11, 08:20 PM | #2 |
Recognitions:
i think so. in general, if M is a maximal ideal in a commutative ring R, then R/M is a field. If R contains a subfield k, then R/M is an extension of k. So in your case the ring K[X] contains the subfield K, and since K[X] is a Euclidean ring, hence also a p.i.d., an irreducible polynomial f generates a maximal ideal, so K[X]/(f) is a field extension of K.
Moreover the degree (vector dimension) of the extension equals the degree of f, hence is finite, and every finite extension is definitely algebraic. so YES! I had to think through all the details since I am old and losing my memory. hope this helps. |
| Jan29-11, 08:23 PM | #3 |
Isn't the answer obvious from the definition of "algebraic extension"? The interesting part is that it's a field and not just a ring.
(Hrm. I suppose there are equivalent definitions, and some would be less obvious than others. Which are you using?) |
| New Reply |
| Thread Tools | |
Similar Threads for: Do Irreducibles Induce Algebraic Extensions?
| Algebraic And Simple Extensions | Calculus & Beyond Homework | 2 | ||
| Galois Theory - Algebraic extensions | Calculus & Beyond Homework | 2 | ||
| Help With Algebraic Extensions/Bases | Calculus & Beyond Homework | 0 | ||
| Counting Number of Irreducibles | Calculus & Beyond Homework | 9 | ||
| [SOLVED] One-particle irreducibles in P&S | Quantum Physics | 2 | ||
