Is There a Calculation Error in Khan Academy's Projectile Motion Video?
The discussion revolves around a video on two-dimensional projectile motion from Khan Academy, specifically addressing the calculation of average velocity in the horizontal direction and its implications for displacement. Participants are questioning the accuracy of the video's claims regarding constant horizontal velocity and the relationship between initial and average velocities.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are exploring the concept of average velocity in projectile motion, particularly in the horizontal direction. Some question whether the average velocity can be considered constant, while others discuss the implications of using different final velocities for horizontal and vertical components.
The discussion is active, with participants providing differing viewpoints on the calculations presented in the video. Some have acknowledged errors in timing, while others emphasize the constancy of horizontal velocity until impact. There is no explicit consensus, but various interpretations of the problem are being explored.
Participants are working within the constraints of the video's content and are referencing specific timestamps. There is an acknowledgment of potential errors in the video's calculations, particularly regarding time and velocity components.
m_scott
http://www.khanacademy.org/video/2-dimensional-projectile-motion--part-3?playlist=Physics
Skip video to 4:40. He says that the average velocity in the horizonatal direction is the same as the initial velocity (7.07m/s) because it doesn't change. but wouldn't the velocity change from 7.07m/s to 0? which means the average velocity should be 3.5m/s, right?
which means the change in displacement should equal 10m, not 20m. right?
You are right.
Hmm, I missed the part you are talking about, after fast forwarding, but as the other users pointed out his time was off by a factor of 2 based on when he first started.
You are wrong that the horizontal direction (did you mean to say vertical?) changes to zero though. Of course, once the ball hits the ground it may splat right in place and go to zero velocity, but we are concerned with the infinitesimal second before it hits.
The horizontal component of velocity is constant up until the moment of impact! So the person in the video is absolutely correct.
BTW: You can only be sure that vavg=(vinitial+vfinal)/2 if the acceleration is constant!
so when you find displacement in the horizontal direction, you shouldn't ever use 0 as your final velocity? You can only use 0 as your final velocity for the y componenet?
And SammyS, he used vavg=(v0+v)/2 to get his answer. is the acceleration not constant?
(btw, i realize his time is wrong. i am looking at this problem based off his time)
For vertical velocity it depends on where you look at the trajectory. If you want to know how high the ball goes the final vertical velocity to get to that height will be 0. If you want to know the vertical velocity before it hits the ground the vertical velocity will be the same as when it was launched (at least given the ball is launched from the ground).
  • · Replies 22 ·
