What is the value of the infinite series?
  • Thread starter Thread starter ptolema
    Infinite Sum
The discussion revolves around evaluating the sum of an infinite series, specifically one that may be represented as a power series centered at zero. Participants are exploring the function defined by this series and its convergence properties.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants are considering various methods to evaluate the infinite series, including the use of Taylor series and power series representations. Some are questioning how to manipulate the series effectively to find its sum, while others suggest specific series transformations and manipulations.
The discussion is active, with participants offering hints and suggestions for approaching the problem. There is a focus on exploring different series manipulations and interpretations without reaching a consensus on a specific solution yet.
Some participants express uncertainty about the power series and the evaluation of infinite series, indicating a need for clarification on these concepts. The original poster has requested pointers, suggesting a level of complexity in the problem that may require further exploration.
ptolema
evaluate the sum:
(it may help to think of this as a value of a function defined by a power series.)
as a function defined by a power series, the function is centered at 0: f(1/3)=
=1/3+4/9+1/3+16/81+...+n2/3n
i'm not entirely clear on how to actually evaluate the value of an infinite series. i could definitely use a few pointers
hi ptolema! :smile:
(have a sigma: ∑ :wink:)
(not sure about the power series, but … )
have you tried ∑ (n+1)2/3n - ∑ n2/3n ? :wink:
ok so how about considering a taylor series about zero as a start
[tex]f(a) = \sum_{n=0} f^n(a) x^n[/tex]
then re-write your series as
[tex]0 + 1.\frac{1}{3} + 2^2.\frac{1}{3^2} +3^2.\frac{1}{3^3} +...+ n^2 (\frac{1}{3^n})[/tex]
[tex]\sum_{n=1}^{\infty} \frac{x^n}{3^n} = \frac{x}{3-x}[/tex] for |x| < 3.
Try fiddling around with various manipulations such as differentiating both sides, and try to lead yourself to a series that will drop out your required sum after a suitable substitution for x.
Going along the hint by tiny-tim, complete the dots below
[tex]\sum_{n=1}^{\infty} \frac{n^2}{3^n} = \sum_{n=0}^{\infty} \frac{(n+1)^2}{3^{n+1}} = \frac{1}{3}\sum_{n=0}^{\infty} \frac{n^2 + 2n +1}{3^n} =...[/tex]
  • · Replies 22 ·
