Relativistic Momentum and Kinetic Energy
The discussion focuses on calculating the speed of an electron with a given momentum of 5 MeV/c using relativistic equations. The user successfully derived the speed as approximately 0.993c by converting units from MeV/c² and MeV/c to kg and kg*m/s. Key equations utilized include the momentum formula p=γmu and the speed formula u=±(cp/√(c²m²+p²)). The conversation highlights the importance of unit consistency in relativistic calculations.
  • Understanding of relativistic momentum and kinetic energy concepts
  • Familiarity with the equations p=γmu and u=±(cp/√(c²m²+p²))
  • Knowledge of unit conversions between MeV/c², MeV/c, and SI units
  • Basic proficiency in using online calculators for physics problems
  • Study the derivation of relativistic momentum and kinetic energy equations
  • Learn about unit conversions in particle physics, specifically MeV to kg
  • Explore the concept of Lorentz factor (γ) and its applications
  • Practice solving problems involving relativistic speeds and momenta
Students studying physics, particularly those focusing on relativistic mechanics, as well as educators and anyone seeking to deepen their understanding of particle momentum and energy calculations.
erok81
What is the speed of an electron (me=0.511 MeV/c2) with a momentum p=5 MeV/c.
Starting with momentum:
[tex]p=\gamma mu[/tex]
Then solving for u:
[tex]u=\pm\frac{cp}{\sqrt{c^2m^2+p^2}}[/tex]
I've never dealt with these units before (MeV/c2 and MeV/c) so I am not sure what to do with them. Can one use those values to solve for speed? I solved it (getting 0.993c) but I converted everything to kg and kg*m/s and the solved from there.
Is there an easy way to convert (if I have to)? I ended up using a calculator online to find values. But I'd rather understand them better.
hi erok81! :smile:
(have a gamma: γ and a square-root: √ and try using the X2 and X2 icons just above the Reply box :wink:)
erok81 said:
I've never dealt with these units before (MeV/c^2 and MeV/c) so I am not sure what to do with them. Can one use those values to solve for speed?
yes
if in doubt, look at the units given to you …
the whole of that square-root bracket is in units of MeV/c2 squared times c2, and (MeV/c)2, which are the same, and the top line is the square-root of that …
everything is in the same units, so the whole thing is just a dimensionless number, just like v/c (you don't even need to convert from MeV to eV) :wink:
Oh hey, what do you know, it worked.
I tried it once before after I solved it using my know units and it didn't match. Now I see why...I messed up the m2 under the radical.
My answer is slightly different, so I'll go back and change it. (0.995 vs. 0.993)
Thanks for the help.
And thanks for pointing out the super/subscript buttons. I never saw those and didn't like using LaTeX in the middle of a sentence just for that.
  • · Replies 54 ·
12K
12K
