What are the forces and tension acting on the top of a connected block system?
  • Thread starter Thread starter Alem2000
    Homework Tension
The discussion revolves around a problem involving two blocks connected by a uniform rope, with an upward force applied. Participants are exploring the forces and tension acting on the system, particularly at the top of the rope and at the midpoint, while considering the effects of gravity and the mass of the rope.
  • Mixed
  • Participants are attempting to apply Newton's second law to analyze the forces acting on the blocks and the rope. There are discussions about calculating the tension at different points in the rope and the effects of the applied force and gravitational forces on the system's acceleration.
Some participants are providing guidance on how to set up the equations for tension and forces, while others are questioning the assumptions made in the problem setup. There is an exploration of different interpretations regarding the relationship between the forces and the resulting tension in the rope.
Participants note that not all information from the original problem is provided, leading to assumptions in their reasoning. There is also mention of the need to consider the mass of the rope and the blocks when calculating tensions.
Alem2000
I am having trouble figuring this out. " Two blocks are connected by a uniform
rope with a mass of [tex]4.00kg[/tex]. An upward force of [tex]200N[/tex] is
applied. ...a)what is the [tex]\vec{a}[/tex] of the system and what is the
tension at the top of the rope.
The [tex]\vec{a}[/tex] of the system would have to be
[tex]\frac{\sum{\vec{F}}}{m}=a[/tex]
[tex]\sum{\vec{F}}=200N-(m_1+m_2+m_3)g[/tex]
which is [tex]200N-147N=53N[/tex]
and then [tex]\frac{53N}{15.0g}=\vec{a}[/tex]
so now for the tension of the top of the rope. What are the forces acting on the top of the rope...there is the [tex]200N[/tex]...and weight of the box hanging from the rope?
Since you haven't provided all the information from the question, I'll have to make some assumptions...but basically you can model this system as a single block of mass (m1+m2) being pulled upwards by a single rope of mass m3. Now the upward force on this system is T, while the total downward force is (m1+m2+m3)g. Use the Second Law to find T.
Apparently you know the masses of the two blocks and the rope. (Since you were able to find the acceleration.)
To find the tension in the top of the rope, consider the top block as your object and apply Newton's 2nd law to it.
Yes I see. But then it asks me to find the tension at the midpoint of the rope. I
start to solve for[tex]T_t[/tex] which is tension at the top
[tex]F-m_1g-T_t=ma[/tex] where the mass is that of the top block and
acceleration is that of the system. The book says the correct set up is
[tex]T_t=F-m(g+a)[/tex] which is the same as mine except the accelaration is
gravity plus the systems...why? I can understand why you would do that.
Those two equations are equivalent.
so to find the [tex]T_m[/tex] tension in the middle of the rope would you
calculate the forces as that of the pull, weight of 1st box, and weight of 1st half
of rope? Like this
[tex]\sum\vec{F}=200N-W_1-\frac{1}{2}W_2[/tex] and
[tex]ma=(m_1+\frac{1}{2}m_2)a[/tex]
of rope?
I would apply Newton's 2nd law to the top box plus half the rope.
Like this
Almost. But you forgot the tension itself:
[tex]\sum\vec{F}=200N-W_1-\frac{1}{2}W_2 - T_m[/tex]
Yes.
  • · Replies 38 ·
  • · Replies 25 ·
