Displacement of zigzaging dust particle
The problem involves a dust particle moving in a zigzag pattern due to bombardment by air molecules, with a focus on calculating the distance traveled over time and the displacement vector after a large number of steps. The context relates to concepts in physics such as Brownian motion and vector addition.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of distance traveled and the average magnitude of the displacement vector after many steps. There are attempts to clarify the use of vector addition and the dot product in this context.
Guidance has been offered regarding the average magnitude of the sum of vectors with random directions. Some participants are exploring the implications of averaging over angles and questioning the assumptions made in earlier parts of the problem.
There is uncertainty regarding the application of the dot product and the assumptions from part (a) in relation to the calculations for part (b). Participants express confusion about the relationship between the average value of cosine and the resulting displacement.
Pseudopro
A particle of dust is bombarded by air molecules and follows a zigzag path at constant speed v.
(a)Assuming each step has a length d, find the distance traveled by the dust particle in time t.
(b)What is the length of the displacement vector after N steps where N is large? Assume that each step is taken in a random direction on the plane. (This problem assumes you are familiar with the scalar product of two vectors.
v2=(v12+v22+...+vN2)/N
The answer to part (a) seemed quite obvious: vt.
However, part (b) isn't so easy. I've been able to get the answer d[tex]\sqrt{N}[/tex] by doing vt=t x sqrt[(v12+v22+...+vN2)/N] but this is getting the answer for the sake of it. My method doesn't actually make any sense because it can cancel out to nothing. Please help!
(I believe this is called Brownian motion?) (the thing I don't get is how do I use dot product in this instance?)
Hi Pseudopro! :smile:
Hint: if you add two vectors whose lengths are fixed as a and b, but whose directions are random,
what is the average magnitude of the sum of those vectors? :wink:
(a+b)/2?
uhh? :confused:
call the angle θ, and work out the magnitude! :rolleyes:
(and then average over θ)
Sorry, I don't think I'm doing this properly (or I don't have the knowledge).
Are you looking for something like this? [tex]\sqrt{a^{2}+b^{2}-2abcos\theta}[/tex]
That's it! :smile:
ok, since θ can be anything, the average value of that is (roughly) … ? :wink:
(and then try the same thing for n vectors)
average value of cos would be 0.5 I think - so it would end up as d... (wait does the assumption from part (a) still hold?) I don't see how I can get sqrt N... if I put d back into the equation, I just get exactly the same thing back again...
Pseudopro said:
average value of cos would be 0.5 I think …
uhh? :confused: average value of cos is zero
oh yeah. my bad...
Thanks a lot for your guidance. :smile: I've got it now :approve:
I am also doing this problem and understand the hints above, but I don't understand how the answer is d[itex]\sqrt{N}[/itex]. Can someone help?? :rolleyes:
I am also doing this problem and understand the hints above, but I don't understand how the answer is d√N. Can someone help?? :rolleyes:
