Understanding Solar Sensor Resolution: Explained and Compared | dacruick
This discussion focuses on understanding sensor resolution, specifically in the context of a 4 quadrant sun sensor. The resolution is defined as the smallest change the sensor can detect, which is influenced primarily by the electronics rather than the sensor itself. A key point made is that digital sensors have a resolution determined by their bit output; for instance, a 6-bit sensor has a maximum resolution of 1 part in 64, as derived from the formula 2^6. The conversation also touches on the relationship between resolution and binary output, emphasizing the importance of aligning electronic resolution with sensor accuracy.
  • Understanding of sensor technology and its components
  • Knowledge of digital output and binary systems
  • Familiarity with resolution concepts in electronics
  • Basic principles of light and optics related to sensors
  • Research "Digital Sensor Resolution" to understand bit output implications
  • Explore "Electronics Limiting Factors in Sensor Accuracy" for deeper insights
  • Learn about "Collimated Light and Sensor Design" to enhance practical applications
  • Investigate "Theoretical vs. Practical Sensor Resolution" for comparative analysis
This discussion is beneficial for engineers, researchers, and hobbyists involved in sensor technology, particularly those working with optical sensors and electronics. It provides foundational knowledge for anyone looking to optimize sensor performance and accuracy.
dacruick
Hi there,
I am doing some research online trying to find a good site that explains to me how sensor resolution works. I have a very vague understanding right now and I was hoping someone could go through it with me. I'll give a bit of background as to the task I have.
I have a 4 quadrant sun sensor, and there is just a pinhole on top of it as to allow a collimated beam of light to enter. I want to tilt this sensor slightly in all directions, and find the smallest angle that the sun sensor can register.
What I want to know:
The resolution is simply the smallest change the sensor is able to detect.
I would like to compare it to the theoretical resolution of the sensor, but I don't know how to figure that out. I also would like to know what governs the resolution of a sensor, and what is the limiting factor in resolution. (is it the sensor itself, or is it the electronics)
There have been references to resolution as exponents of 2. why is that the case?
I'm sorry if this post isn't very well organized, any help at all would be appreciated.
Thanks,
dacruick
That's generally just a limitation of the electronics. Anything with a digital output will have a given number of bits (binary digits) of output. Say for example that a sensor has a 6 bit digital output then it's maximum resolution would typically be 1 part in 64 (64=2^6), as 2^6 is the number of binary codes you can make with 6 bits.
So it should never really be the electronics that limit the resolution. You should just make your electronic resolution so that it just covers the sensor output's accuracy.
  • · Replies 23 ·
10K
  • · Replies 21 ·
11K
