Max Range Lab: Solving the Units Problem
The discussion focuses on solving the units problem in the context of a lab report analyzing projectile motion. The user is utilizing the range equation with initial velocity (V0 = 4 m/s) and launch angle (theta = 45 degrees) but encounters unit discrepancies. By adjusting the equation to incorporate V0 cos(theta) inside the radical, the user resolves the unit mismatch, leading to a more accurate calculation of the range (R). This adjustment increases the calculated range, aligning it more closely with empirical data.
  • Understanding of projectile motion principles
  • Familiarity with the range equation in physics
  • Basic knowledge of trigonometric functions (sine and cosine)
  • Ability to manipulate algebraic equations
  • Study the derivation of the range equation for projectile motion
  • Learn about the effects of launch angle on projectile range
  • Explore unit consistency in physics equations
  • Investigate the impact of initial velocity on projectile trajectories
Students in physics courses, educators teaching projectile motion, and anyone involved in lab reports related to kinematics and dynamics.
haxtor21
I am doing a lab report where I have to find a maximum range and at what angle it occurs. For the range equation I am using a range equation with the initial velocity, theta, g and h as variables. There clearly is a problem since my units do not match up, and I can't find what it is. h has to be zero since the projectile was shot at h=0. Eliminating h still doesn't solve the units problem, but the answer does conform more with my data, but still is 20% off.
V0=4 m/s
theta=45 deg.
http://img12.imageshack.us/img12/2074/gedc0204a.jpg
Uploaded with ImageShack.us
http://img842.imageshack.us/img842/9617/gedc0205.jpg
When you bring the term V0 cosθ inside the radical, and it becomes V02 cos2θ, the first term in the radical should be
V02 cos2θ * V02 sin2θ
= V04 sin2θ cos2θ​
and then the units agree. (And transform to sin22θ as appropriate, of course.)
This will make your calculated R larger.
  • · Replies 21 ·
28K
