Sketching the Graph: Seeking Help & Solutions
  • Thread starter Thread starter aurao2003
    Graph
The discussion revolves around sketching the graph of a rational function, specifically focusing on identifying vertical and horizontal asymptotes. The original poster expresses uncertainty about the horizontal asymptote after determining the vertical asymptote at x = -2.
  • Participants discuss the rules for determining horizontal asymptotes, particularly when the degrees of the numerator and denominator are equal. There are suggestions to examine the behavior of the function as x approaches infinity and to consider specific points for sketching the graph.
Some participants provide guidance on how to approach the problem, including referencing rules for asymptotes and suggesting methods for verifying the horizontal asymptote. Multiple interpretations of the function's behavior are being explored, particularly regarding the asymptotic behavior as x tends to infinity.
There is mention of the original poster studying independently, which may influence the level of detail in the discussion. Additionally, some confusion arises from the interpretation of the function itself, indicating a need for clarity in the problem setup.
aurao2003
Hi
I am trying to understand how to sketch the above named graph.
I have obtained the vertical asymptote as x = -2 but not sure of the horizontal asymptote. Examining the graph as x tends to infinty, it seems the horizontal asymptote is 1. But I am stuck at this stage. Any help or suggestions? I am not sure of the shape of the graph also. Thanks.
1: What's the rule for determining the horizontal asymptote when the highest power of x on the bottom is the same as that on the top? This will help you learn WHY there is a horizontal asymptote at y=1. You MUST say it is at y=1, just saying 1 would be counted wrong on a test or quiz.
2: Make dotted or slashed lines for the horizontal and vertical asymptote.
3: Determine whether it goes to plus or minus infinity. Do for both sides of vertical asymptote.
4: Pick a point, on both sides, that will be easy to go through, such as x = -3 and x = -1, since it will be a nice integer point.
5: Do your best, remember to go through those points, as they help you stay on track and remember which side goes which way. Also, remember that the farther away from the vertical asymptote, the closer you get to the horizontal asymptote.
This is just to give you an idea of how to solve this type of problem, It's by no means all inclusive.
Well, thanks. I am studying independently. So, the only test is the exam or by myself. I am not sure about the rule. Kindly tell me. Thanks.
Right, no wonder I was scratching my head thinking why there is so much discussion on this question. It's actually x/(x+2), not x/x+2=1+2 :biggrin:
One of those days?:-p
Pretty much :cry:
By the way, to show there is an asymptote at y=1, you can try this -
[tex]y=\frac{x}{x+2}[/tex]
[tex]=\frac{x+2-2}{x+2}[/tex]
[tex]=\frac{x+2}{x+2}-\frac{2}{x+2}[/tex]
[tex]=1-\frac{2}{x+2}[/tex]
Now all you need to do is take the limit as [itex]x \to \infty[/itex] and show this leaves y=1. So then there is an asymptote there.
edit: or even more simply, multiply the fraction by [tex]1=\frac{\left(\frac{1}{x}\right)}{\left(\frac{1}{x}\right)}[/tex] and then again take the limit as [itex]x\to \infty[/itex] :wink:
Mentallic said:
Pretty much :cry:
Cool! Thanks.
  • · Replies 17 ·
  • · Replies 21 ·
