Another question to do with snells law, argh
  • Thread starter Thread starter benhorris
    Law
The discussion centers on calculating the apparent depth of a coin submerged in 0.5 m of water using Snell's Law. The index of refraction for air is 1, while for water it is 1.33. To find the apparent depth, one must determine the angle of incidence and the angle of refraction based on these indices. By applying Snell's Law, the apparent position of the coin can be calculated, aiding in the design of a side-show game for fundraising.
  • Understanding of Snell's Law and its application
  • Basic knowledge of light refraction and angles
  • Familiarity with indices of refraction for different media
  • Ability to draw and interpret ray diagrams
  • Study Snell's Law in detail, focusing on its mathematical formulation
  • Learn to draw ray diagrams for various refraction scenarios
  • Research the indices of refraction for different materials
  • Explore practical applications of refraction in optical devices
Students studying physics, educators teaching optics, and anyone interested in practical applications of light refraction in games or demonstrations.
benhorris
A student decides to use the tank and water to make a side-show game to raise money at a fete. She places a coin on the bottom of the tank and invites people to drop more coins into cover it – apparently easy to do until you try it. The water is 0.5 m deep. When someone looks vertically into the tank, how far below the surface does the coin appear to be?
Please help, i have no idea how to do this...
thank you... :-)
Consider the coin as a source of light. Follow a ray of light (at some angle [itex]\theta[/itex] to the normal) from the coin through the water and into the air. Which way does it bend when it hits the air? By what angle? So, considering the light from the coin after it gets bent at the surface and hits your eye, where does the coin appear to be? (Extend the ray of light that hits your eye straight back to find the apparent position of the source.)
To calculate the apparent depth of the coin, we will need to use Snell's Law, which states that the ratio of the sine of the angle of incidence to the sine of the angle of refraction is equal to the ratio of the indices of refraction of the two media involved. In this case, the two media are air and water.
First, we need to determine the angle of incidence. This can be done by drawing a diagram, where the normal line (perpendicular to the surface of the water) intersects with the incident ray (the line from the observer's eye to the coin). The angle between these two lines is the angle of incidence.
Next, we need to determine the angle of refraction. This can be done by using Snell's Law and the indices of refraction for air and water. The index of refraction for air is 1, while the index of refraction for water is 1.33.
Once we have both angles, we can use the formula for Snell's Law to calculate the apparent depth of the coin. This can be done by rearranging the formula to solve for the distance below the surface, which would be the apparent depth.
It may be helpful to look up a tutorial or example problem on Snell's Law to get a better understanding of the process. Good luck with your side-show game and fundraising efforts!
15K
12K
