How Do Capacitors Behave in Series and Parallel Configurations?
  • Thread starter Thread starter Rblswimmer456
    Capacitors Series
The discussion focuses on the behavior of capacitors in series and parallel configurations, specifically addressing a problem involving two capacitors with an equivalent capacitance of 2.6 μF in parallel. When connected in series, the equivalent capacitance is one-fourth of one of the capacitors. The solution involves using the formula for series capacitance, Cs = 1/(1/C1 + 1/C2), and substituting the known values to derive the capacitances of the individual capacitors, C1 and C2.
  • Understanding of capacitor configurations (series and parallel)
  • Familiarity with capacitance formulas
  • Basic algebraic manipulation skills
  • Knowledge of equivalent capacitance calculations
  • Study the derivation of series and parallel capacitance formulas
  • Practice solving capacitor problems with varying configurations
  • Explore the impact of dielectric materials on capacitance
  • Learn about real-world applications of capacitors in circuits
Students studying electrical engineering, educators teaching circuit theory, and hobbyists interested in electronics and capacitor behavior.
Rblswimmer456
When two capacitors are connected parallel,
the equivalent capacitance is 2.6 μF. If the
same capacitors are reconnected in series, the
equivalent capacitance is one-fourth the ca-
pacitance of one of the two capacitors.
PART A: Determine the capacitance of the larger capacitor
Answer in units of μF.
PART B: Determine the capacitance of the smaller capacitor.
[tex]\frac{1}{C<sub>s</sub>}[/tex] = [tex]\frac{1}{C<sub>1</sub>}[/tex] + [tex]\frac{1}{C<sub>2</sub><br /> }[/tex]
1) [tex]\frac{1}{(\frac{1}{4}C<sub>s</sub>}[/tex] = [tex]\frac{1}{C<sub>1</sub>}[/tex] + [tex]\frac{1}{C<sub>2</sub><br /> }[/tex]
2) C2 = 2.6-C1
3) [tex]\frac{1}{(\frac{1}{4}C<sub>s</sub>}[/tex] = [tex]\frac{1}{C<sub>1</sub>}[/tex] + [tex]\frac{1}{2.1-C<sub>1</sub><br /> }[/tex]
..and I have no idea how to go from here?
"...the equivalent capacitance is one-fourth the capacitance of one of the two capacitors."
You need to pick one of the capacitors, C1 or C2 (it doesn't matter which) and take 1/4 of it, to replace Cs in your equation for the equivalent capacitance of the series connection. With Cs out of the picture you should be able to solve for C1 and C2.
[tex]C_s= \frac{1}{4}\ C_1[/tex]
Your equation (3) should be:
[tex]\frac{1}{\frac{1}{4}C_1}=\frac{1}{C_1}+\frac{1}{2.6-C_1}[/tex]
Of course, [tex]\frac{1}{\frac{1}{4}C_1}=\frac{4}{C_1}[/tex]
14K
