What Is the Lambert W Function and How Does It Solve Transcendental Equations?
  • Thread starter Thread starter pergradus
The discussion revolves around a transcendental equation presented by the original poster, which involves the expression \(\frac{xe^x}{e^x -1} - 5 = 0\). Participants explore the nature of the equation and potential methods for finding a numerical solution for \(x\), particularly considering the Lambert W function.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Some participants suggest that the equation cannot be solved using elementary algebraic methods and propose that it may require the Lambert function. Others discuss the possibility of visualizing the solution through graphing the left-hand and right-hand sides of the equation to find intersection points. Questions arise about the nature of transcendental equations and the criteria for identifying them.
The discussion is ongoing, with participants providing insights into the use of the Lambert W function and the graphical approach to finding solutions. There is a recognition of the equation's complexity and the need for further exploration of its properties. Some participants express uncertainty about the analytic solvability of the equation.
There is a mention of the equation's relevance to deriving Wein's Law, indicating that it is part of a larger problem context. Additionally, some participants question whether the problem is appropriate for homework, suggesting it may involve concepts not yet covered in their studies.
pergradus
I came up against this equation doing some homework and couldn't figure out how to solve it. I need a numerical value for x.
[tex]\frac{xe^x}{e^x -1} - 5 = 0[/tex]Maybe I'm just forgetting some basic log rules or something, but how would you solve this?
This doesn't look like it can be solved using (elementary) algebraic methods. Assuming the question was copied correctly, maybe solving this involves the Lambert function?
This is what is called a transcendental equation and there is no algebraic way to solve it. Instead you can consider the solution as the intersection of two graphs in this way:
Simplifying your equation, we obtain,
[tex]\frac{x}{5} = -e^{-x} + 1, x \neq 0,[/tex]
one can then plot two graphs, one graph for the function on the LHS, and the other for the function on the RHS. Intersection points are your solutions.
The solution is needed to derive Wein's Law by differentiating Plancks function with respect to lambda. So it's part of a larger problem. Not sure what the Lambert function is.
LaTeX Code: \\frac{x}{5} = -e^{-x} + 1, x \\neq 0
Hmm thanks for the tip. Is there no analytic way to solve it though? Also, how do you know it is transcendental by looking at it?
pergradus said:
The solution is needed to derive Wein's Law by differentiating Plancks function with respect to lambda. So it's part of a larger problem. Not sure what the Lambert function is.Hmm thanks for the tip. Is there no analytic way to solve it though? Also, how do you know it is transcendental by looking at it?
Please, also see here who the Lambert function is http://en.wikipedia.org/wiki/Lambert_function. The article is well written.
The graphic intersection solution is the one to use and using a calculator, you can get a 3,4 decimal approximation of the solution.
Was this actually a homework problem? It seems a very peculiar problem for homework. Especially if you have not yet been introduced to "transcendental functions" or "transcendental equations". As dextercioby said, it can be solved using Lambert's W function which is defined as the inverse function to [itex]xe^x[/itex]
That is, you can manipulate this equation to be [itex]ye^y= constant[/itex] and then say that [itex]y= W(constant)[/itex] where "W" is Lambert's W function.
  • · Replies 27 ·
