Optimal Placement of Seismographs w/12 Instruments
  • Thread starter Thread starter webbwbb
    Placement
The optimal placement of 12 seismographs, or seismometers, on a planet requires an even distribution across the surface. A geometrical approach suggests using a dodecahedron, which has 12 nodes uniformly distributed. While theoretical placement can be calculated using tools like Google Earth Mars view, practical considerations such as geographical obstacles must also be taken into account. This discussion confirms that the forum is appropriate for exploring such topics.
  • Understanding of seismographs and seismometers
  • Familiarity with geometric shapes, specifically the dodecahedron
  • Basic knowledge of planetary geography
  • Experience with Google Earth or similar mapping tools
  • Research the geometric properties of the dodecahedron for optimal placement strategies
  • Explore the use of Google Earth for planetary mapping and analysis
  • Investigate practical challenges in seismograph deployment on various planetary surfaces
  • Study geological factors that influence seismic activity on different planets
Geologists, planetary scientists, researchers in seismology, and anyone involved in the deployment of seismographs for planetary exploration will benefit from this discussion.
webbwbb
I am curious in knowing the something about the "optimal" placements of seismographs in a planet. Assuming you know nothing about the geography of a planet and want to learn the most you can and only have 12 seismographs to use, where would you place them? I honestly do not know if this is the right forum for this topic but it seemed like the most fitting of any here. Thank you for your help.
By seismographs I assume you mean seismometers, i.e. the actual instruments. If you know nothing then put them at an even distribution. What would be the name of the 3-D shape with 12 nodes uniformly distributed over the surface of a sphere? (Note this would not be possible on a planet like Earth with ocean blocking the way of a conventional seismometer. There are practical considerations as well, as it might be technically more difficult (expensive) to achieve perfect spread, but I am ignoring those considerations.)
If you do know something about the geology then you have a different question -- perhaps we can talk about that in a different post?
And yes, this is the right forum for this topic.
Thank you. The name of that geometric figure is a dodcahedron. I was able to figure out the coordinates for placement with Google Earth Mars view.
  • · Replies 40 ·
