DBB vs EPR & GHZ: Questions & Answers
  • Context: Graduate
  • Thread starter Thread starter Dmitry67
    Epr
The discussion revolves around the compatibility and implications of different quantum theories, specifically de Broglie-Bohm (dBB) theory, Einstein-Podolsky-Rosen (EPR) scenarios, and Greenberger-Horne-Zeilinger (GHZ) states. Participants explore the relationships between these theories, particularly in terms of hidden variables, non-locality, and the strength of entanglement in various configurations.
  • Some participants assert that dBB, as a hidden variable theory, must be non-local and question how this non-locality interacts with GHZ states.
  • Questions are raised about whether dBB requires additional assumptions to make correct predictions for GHZ scenarios.
  • There is a discussion on the concept of "strength" in EPR scenarios, with some participants suggesting that EPR(N+1) is always "stronger" than EPR(N), while others seek clarification on this notion.
  • One participant references a paper discussing violations of local realism in the context of entangled quantum systems, suggesting that the strength of these violations increases with the dimensionality of the systems involved.
  • Clarifications are sought regarding the specific versions of dBB being discussed, particularly whether they pertain to non-relativistic or relativistic frameworks.
Participants express differing views on the compatibility of dBB with EPR and GHZ states, as well as the interpretation of "strength" in EPR scenarios. There is no consensus on the answers to the posed questions, and multiple competing views remain present throughout the discussion.
Some assumptions regarding the definitions of "stronger" and the specifics of dBB theory are not fully articulated, leading to potential ambiguity in the discussion. The relationship between the number of observers and the strength of EPR scenarios is also not clearly defined.
Dmitry67
dBB, as a theory with hidden variables, must be non-local.
So there is some magic how 'particles' affect each other with superluminal speed.
I don't care about the details, I know that somehow these rules are adjusted to satisfy Bell.
My questions:
1. is dBB also 'compatible' with GHZ?
2. does it need any extra assumptions to give correct predictions for GHZ?
Then, assuming some generalization - EPR with 2 observers is EPR(2), GHZ with 3 observers is EPR(3) - and I know that EPR(3) is "stronger" than EPR(2):
3. is EPR(N+1) always "stronger" than EPR(N)?
4. is dBB compatible with any EPR(N)?
I'm disappointed. Turns out this thread had nothing to do with Electron Paramagnetic Resonance in the Gigahertz range.. :)
1. Yes
2. No
3. What do you mean by "stronger"?
4. Yes
3. In a sense that GHZ is "stronger" than EPR
For example:
http://iftia9.univ.gda.pl/~pg/prace/2000PhRvL..85.4418K.pdf
We investigate the general case of two entangled quantum systems defined in N-dimensional Hilbert spaces, or “quNits.” Via a numerical linear optimization method we show that violations of local realism are stronger for two maximally entangled quNits (3 # N # 9) than for two qubits and that they increase with N.
Now when you answer "Yes" to the other questions you mean:
1. Non-relativistic dBB
2. Your version of relativistic dBB?
Both.
For example:
In the paper above, N is not the number of observers.
  • · Replies 225 ·
16K
  • · Replies 58 ·
  • · Replies 17 ·
  • · Replies 100 ·
12K
  • · Replies 47 ·
