Maximizing Distance for Clowns Shot from a Cannon
The maximum distance D that a clown can travel when shot from a cannon at a speed of 11.7 m/s, with the landing pad at the same height as the cannon, is calculated using projectile motion equations. The optimal launch angle for maximum distance is 45 degrees. To have two clowns land simultaneously at a distance of 0.54×D, the first clown should be fired at an angle of approximately 36.87 degrees, while the second clown should be fired at an angle of approximately 53.13 degrees. The second clown should be fired 0.5 seconds after the first clown to ensure they land at the same time.
  • Understanding of projectile motion principles
  • Knowledge of trigonometric functions and their applications
  • Familiarity with kinematic equations
  • Basic knowledge of timing and synchronization in physics
  • Study the derivation of projectile motion equations
  • Learn about the effects of launch angles on projectile distance
  • Explore the concept of simultaneous projectile launches
  • Investigate real-world applications of projectile motion in entertainment and sports
Physics students, circus performers, and anyone interested in the mechanics of projectile motion and its applications in entertainment scenarios.
darkbiology
In a circus act, clowns are shot from a cannon at a constant speed vo = 11.7 m/s. The angle of launch may be varied.
a. What is the maximum distance D that a clown may travel, if the landing pad is at the same height as the mouth of the cannon?
b. The circus master wants to shoot two clowns from his cannon, one after the other, and have them land on the same landing pad a distance 0.54×D away at the same time. At what angle should the first clown be fired?
c. At what angle should the second clown be fired?
d. How long after the first clown should the second clown be fired?
Welcome to PF.
You need to post an attempt at a solution and/or the specific part(s) you have a question about.
