| New Reply |
Constant velocity down a slope |
Share Thread | Thread Tools |
| Feb26-11, 06:31 AM | #1 |
Would constant velocity down a slope be achieved by a cart, by having the frictional force equal to that of Wsinθ (Where W is the weight force and θ is the angle between the slope and the horizontal). 2. Relevant equations/3. The attempt at a solution For example if θ was equal to 15 and W was equal to 19. Then to achieve a constant velocity the frictional force would need to equal approximately 4.92 N. Or am I going in the wrong direction with this? Any help is appreciated and please excuse any ambiguity within this post. |
| Feb26-11, 07:57 AM | #2 |
hi phy124! welcome to pf!
![]() good ol' Newton's second law in that direction means that ∑F = 0, so friction = Wsinθ … what is worrying you about that? |
| Feb27-11, 12:26 AM | #3 |
| Feb27-11, 03:01 AM | #4 |
hi phy124!
![]() (just got up …) …yes, if there's wheels and no brakes, then the friction with the ground is irrelevant (there is no work done ) … the only thing slowing the cart is friction in the bearings (between the wheel and the axle), and air resistance … usually not enough to overcome gravity and keep a constant velocity! ![]() (actually you're wrong about the direction of friction from the ground … for driving or braking wheels, attached to the engine, the friction is in the same direction as the acceleration or braking, but for non-driving non-braking wheels, surprisingly it's in the opposite direction! )
| Feb27-11, 04:40 AM | #5 |
Hi,
The cart is given three forces: gravity(W), support force(N) and frictional resisntance(F). If the cart is moving with constant velocity along the slope, the force along the slope should be zero, which means Wsinθ = F. As for dynamic frictional resistance, we have the equation F= Nμ, where μ is friction coefficient. Another equation we have is N = Wcosθ. So the final equation to satify your requirement is tanθ = μ. Without information about the friction coefficient, we could get the answer. |
| Feb27-11, 04:51 AM | #6 |
hi 9une! welcome to pf!
| Feb27-11, 04:57 AM | #7 |
no, as phy124 points out, µ is irrelevant if the cart has wheels and no brakes
[/QUOTE]In my opinion, µ is decided by wheels and brakes. How could we say µ is irrelevant? |
| Feb27-11, 05:13 AM | #8 |
have some coffee! …
| Feb27-11, 10:55 PM | #9 |
| New Reply |
| Tags |
| constant, momentum, slope, velocity |
| Thread Tools | |
Similar Threads for: Constant velocity down a slope
| A question about constant velocity/constant acceleration graphs? | Introductory Physics Homework | 2 | ||
| Physics of a runner (Constant Acceleration/ constant velocity) | Introductory Physics Homework | 1 | ||
| find angular velocity from constant linear velocity | Introductory Physics Homework | 1 | ||
| Constant-amplitude vs. constant-velocity, in layman's terms | Electrical Engineering | 2 | ||
| constant velocity and constant acce | Introductory Physics Homework | 2 | ||
