Can a button replace the foot lever for gear shifting on a motorbike?
  • Thread starter Thread starter rohitkpandey
    Mechanical Project
A project is proposed to develop a button-operated electromagnetic gear shifting system for motorbikes, replacing the traditional foot lever. The concept involves using a stepper motor and solenoids to facilitate gear changes. Participants in the discussion seek clarification on the project's principles and potential design ideas. Suggestions for modifications to the gearbox are encouraged to enhance the system's functionality. The goal is to innovate the gear shifting process in two-wheelers through this technology.
rohitkpandey
Hi friends ! I am a student of mechanical engg final year.I have to submit a project.
I think to make a project on
"Button operated electromagnetic gear shifting system for two wheeler "
can someone help me how could be the principal?
Is that a motorbike or a pushbike? What exactly are you looking for? 'principal'? Some possible concepts? Can you give more details.
Actually it will be a motorbike in which we change gears by a button instead of leaver on foot as in bikes now a days. For that we have to work on some changes in gearbox maybe by using a stepper motor and solenoids. What are your ideas about that?
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
