| New Reply |
sizing pipe threaded elements |
Share Thread | Thread Tools |
| Feb27-11, 11:46 AM | #1 |
Hi to everyone,
I have a problem with sizing pipe threaded elements. I am looking for guide rules that with a simple external meassurement I'll be able to determine the element size such as safety valves,threaded pipes,pressure gages,caps etc. To clarify my question, hereby an example, when I meassure 1/2" safety valve, I can't relate the 1/2" to the actual possible meassurements (ext/int dia) of this valve. The same problem, when meassuring a threaded hole in a vessele.. I hope that I need not to take several meassurements (ext&int dia, thickness, pitch, number of threads per inch...) and than look at the tables to which size it fits. Thanks, Guideon |
| Feb27-11, 11:49 AM | #2 |
The threads are probably National Pipe Thread Taper (NPT). You can find dimension charts online.
| Feb27-11, 10:18 PM | #3 |
| Feb28-11, 07:19 AM | #4 |
Thanks, Guideon
| Feb28-11, 08:51 AM | #5 |
This sort of thing is done by standard. You can use loads of different thread types. NPT are good for about 10k psi if I remember correctly. Above that you'll need to use something different.
Look at a catalogue of someone who sells connetors. So Swagelok, Autoclave engineers, etc. |
| New Reply |
| Thread Tools | |
Similar Threads for: sizing pipe threaded elements
| Exhaust pipe sizing | Mechanical Engineering | 22 | ||
| Steam system pipe sizing inquiry | Engineering Systems & Design | 0 | ||
| Hazen william Vs Darcy (pipe sizing) | Mechanical Engineering | 8 | ||
| Two cylindrical tanks, connecting pipe and outlet pipe - Differential Equation | Calculus & Beyond Homework | 5 | ||
| Threaded screws | Introductory Physics Homework | 0 | ||
