Low Profile Tyres: Cornering Pros & Cons
  • Thread starter Thread starter wolram
The discussion revolves around the impact of low profile tyres on cornering performance, exploring whether they enhance or hinder grip compared to high profile tyres. Participants examine various factors influencing cornering, including sidewall flex, rubber compounds, tread design, and the implications for different driving conditions and vehicle types.
  • Some participants argue that low profile tyres improve cornering due to reduced sidewall flex, while others believe high profile tyres provide better grip because of increased sidewall flexibility.
  • One participant suggests that cornering performance is more influenced by rubber compound, tread design, and contact patch rather than sidewall height.
  • Another contributor notes that race cars often do not use low profile tyres, citing NASCAR and IndyCar as examples, but acknowledges that some racing categories do utilize them.
  • It is mentioned that tyres behave like springs, and sidewall properties can impact handling, with some participants referencing NASCAR's regulations regarding tyre spring rates.
  • A participant expresses uncertainty about the relationship between sidewall height and grip, suggesting that higher aspect ratio tyres may lead to a more gradual loss of grip compared to low profile tyres, which could snap suddenly.
  • One response emphasizes that the coefficient of friction and material shear strength are critical for cornering, asserting that all tyres can achieve similar cornering forces under ideal conditions, but performance varies on imperfect surfaces.
  • Another participant discusses the balance between responsiveness and contact with the road, suggesting that lower profile tyres may feel more responsive but could struggle to maintain contact over irregularities.
Participants express differing views on the effects of low versus high profile tyres on cornering, with no consensus reached. The discussion includes multiple competing perspectives on the factors that influence cornering performance.
Some claims rely on specific assumptions about vehicle setup, driving conditions, and the characteristics of different tyre types. The discussion does not resolve the complexities of how various factors interact in real-world scenarios.
wolram
Dearly Missed
Do low profile tyres make cornering better, (the side wall flexes less ) or worse, (high profile flexes more), i think the high profile would give a better grip when cornering,
I wouldn't think that sidewall height would have much to do with cornering, it would have more to do with rubber compound, tread design and width(contact patch). The size of sidewall would cause more or less give, but it wouldn't be very perceptible until you got up to large sidewalls, like on large 4x4's but then you can counteract that by getting higher ply tires. I haven't seen many race cars that use low profile tires, nascar doesn't and neither does indy and they spend lot of their days in high speed cornering. One thing that low profiles will get you is more rim replacement, unless your very, very careful about hitting bumps, potholes, curbs and other roadside hazards plus they will give you a noisier and rougher ride, ime.
tires act like SPRINGS so the sidewall properties do impact handling...in fact NASCAR outlawed tire dynometers as cost savings ...seems car teams found tries had diffeent spring rates and the ycould mix and match these to assist in correcting cornering problems ..in lieu of inserting/ removing spring rubbers...
just some trivia for the record...RM
I really should stay out of tyre debates, rubber is all black magic, I only have a rudimentary understanding of what's going on with rubbers.
Low profile sidewalls (high aspect ratio) make stiffer tyres. Obviosly at a certain slip angle the tyre creates/expereince a certain lateral force. When that force is deflecting the tyre it's not turning the car. So the turn in and cornering will feel more consistent throughout the corner.
I may be wrong about this, but from expereince.
I'm fairly sure that a tyre with a higher aspect ratio will make the tyre more prone to 'snapping'. So the fall off when the maximum grip is exceeded will be sudden and without much warning. Tall tyres lose grip really gradually giving the driver plenty of time to correct.
So a tall tyre will start to understeer quite gradually letting you know it's running out of grip. The low profile tyre will go from lots of cornering to no cornering very quickly.
Also regarding about race cars not having low profile tyres, this isn't strictly true. It depends what sport and the specific demands of the tyre. Sportcars, LMPs, GTs and Touring cars do tend to have low profile tyres.
yeah Chris, the whole thing can take on a life of its own...i would perfer to let it ride..no pun intended..the tire thing gets ahiry when belted vs radial ply comes in..then material, kelvar, fiberglass, stell belt gets included, so sometimes is is cheaper to run what therules say and concnetrate on othe performace areas...
First off, leaving out the car setup, COG, etc. it is only the compound that matters. Coefficient of friction and the material shear strength are really what matters. The problem with this is that the highest friction materials with adequate shear strength will not provide much of a tire life. Once you factor in a material that has adequate tread life (say 30 to 40k miles) that has all of these above properties you can compare them.
For standard road driving, you will have to deal with imperfections in the surface, like potholes, bumps, chatter, etc that we all find when driving. The tire and compound and aspect ratios we have picked all can handle the lateral force that we will put on it up to the point where it exceeds the COF. This means they all will corner right up to the same cornering g-force before you skid off the road. The aspect ratio in this range is about 15-70 or so due to mechanics, but that is another story. This range of aspect will all have the same tire height for our comparison, so just say they are all 30" tall, so the COG never changes.
This means on a perfect road they will all corner exactly the same. The lower profile will feel more snappy and responsive, due to the least amount of movement required to load the sidewall into the turn, but does not effect the cornering ability. This also feels more responsive for going through a s-curve when transferring weight directly from one corner into an opposite corner. Again, the cornering ability is not affected though.
Once you put this on a regular road with imperfections, it simply becomes a matter of which tire stays in contact with the road, since the cornering is equal in all of them, for a tire in the air handles ZERO lateral force. Super low profile tires have virtually zero ability to respond to bumps pneumatically, instead depending on the suspension alone (remember that this car always has the exact same suspension system). Pneumatic response in a tire is always faster than suspension response due to the suspension have to transfer weight. High profile tires can absorb more irregularity and stay in contact with the road better, but they run into the practical problem (not theory) of tread rolling to lose contact. This really starts happening at about 75 profile with modern manufacturing techniques.
So, the question is, out of the tires that all give us the same ultimate cornering that we want, which will stay in contact best with the road surface as it changes? Factoring in the two limits from above, this is generally in the 50 to 60 aspect with current manufacturing.
F1 and Indy use 50, NASCAR use 54.
I wrote a bunch more, and I got logged out so I am just putting in what I had in my clipboard :-(
After several paragraphs, here is the bottom line. Properly inflated tires on a standard car: 50-55 on the front and 55-60 on the back will give you the best cornering on regular streets.
Please comment if you like.
  • · Replies 20 ·
