Would a pile of feathers weigh the same as a pile of gold at Earth's center?
  • Context: High School
  • Thread starter Thread starter Goongyae
The discussion revolves around the comparative weight of an ounce of feathers versus an ounce of gold, particularly considering the effects of local gravitational variations and buoyant forces. Participants explore theoretical implications of weight at different altitudes and the impact of density on weight perception.
  • Some participants assert that while the mass of an ounce of feathers and an ounce of gold is the same, their weights may differ due to local gravitational fluctuations.
  • One participant argues that the center of mass of feathers, being less dense, would be at a higher altitude, resulting in a lower gravitational force acting on them compared to gold.
  • Another participant calculates that the relative difference in weight due to height could be about 1 in 10 million, while buoyant force differences could account for a larger effect of about 1 in 1000.
  • Several participants mention that the ounce of gold is approximately 10% heavier than the ounce of feathers, although this is contested by others who note that a pound of gold is less massive than a pound of feathers.
  • A participant introduces a real-world example of how variations in local gravity affected a shuttle experiment, linking it to the broader implications of gravitational differences.
Participants generally agree that mass is the same for both materials, but there is no consensus on whether their weights are the same due to the effects of local gravity and buoyancy. Multiple competing views remain regarding the significance of these factors.
Discussions include assumptions about the density of feathers and the implications of gravitational variations based on altitude. The calculations presented rely on specific conditions that may not be universally applicable.
Goongyae
What weighs more?
An ounce of feathers?
Or an ounce of gold?
Well, obviously, their mass is the same. But does that mean that they weigh thesame? I think not: an ounce of feathers will take up more place than an ounce of gold. Therefore, the feathers will be more prown to local fluctuations of g. In particular, the center of mass of the feathers will be at an higher altitude then with the gold. Thus g for the feathers will be a bit lower. This is why I think that the weight of the feathers is less then the weight of the gold!
Answer: the ounce of gold will be noticeably heavier than the ounce of feathers.
Because precious metals are conventionally measured in troy ounces, not in avoirdupois ounces.
Ounces are a measure of weight or a measure of volume. However, using your logic, they could have a slightly different mass - in this case, somewhere in the 1 millislug range (:rolleyes:).
[Ignoring the QI klaxons]
The correction in g goes like 2h/R (R is Earth's radius). So, for a pile of feathers that's a whopping 60 cm high, the relative difference of weight is about 60cm/6000km or about 1 in 10 million.
On the other hand, there is a much bigger effect, somewhere in the region of 1 in 1000, from the difference in buoyant force (I assumed that feathers have a density similar to most organic matter, somewhere in the range of 1g/cc).
Wow, I thought that nobody would take my answer seriously. But you guys even did the calculations :biggrin: I really love this forum :!)
BTW the ounce of gold will be about 10% heavier than the ounce of feathers.
Variations in the local g are very important to satellite attitude control.
In fact, this caused a problem with one of the shuttle experiments. The goal was to take measurements of the Earth's magnetic field. Unfortunately, electrical currents in the shuttle create their own magnetic field, so the magnetic sensor had to be located far enough away from the Shuttle that the sensor wouldn't detect the shuttle's magnetic field. Putting that sensor out on the end of a long boom put it into a slightly weaker gravity. Since it was obviously going the same speed as the shuttle, it meant the sensor at the end of the boom should pull further away from the Earth than the shuttle, creating a constant torque which would cost the shuttle fuel to counter with its thrusters, and thereby shorten the mission.
The 'solution' was a hose that went along the boom and let fuel leak out at the end of the boom. Even though it generated a tiny amount of 'thrust', the torque generated was equal to the thrust times the radius (the length of the boom). Unfortunately, the hose became clogged and they wound up having to shorten the mission anyway.
Are you trying to hijack this thread? :smile:
On the other hand, a pound of gold is about 18% less massive than a pound of feathers.
Gotta love those English units!
Most of the gold is deep in the earth. If it was at Earth's center, would it weigh anything?
Most feathers might be closer to Earth's surface where g = 9.8m/s/s.
  • · Replies 0 ·
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 59 ·
