| New Reply |
Heat conduction through a slab with internal heat generation |
Share Thread | Thread Tools |
| Mar3-11, 10:44 PM | #1 |
There's a slab of a material with temperature T1 on the left and the T2 on the right. The thickness of the material is l with area A. In the centre, there is heat generation Qvol in the centre, which is a thin rod. Find the heat transfer Q through the material. 2. Relevant equations 3. The attempt at a solution My issue is with modeling the Qvol. If it was heat generation through the material, I'd just use the DE D2T/dt2 = -(1/k)Qvol with BCs T(0) = T1 T(l) = T2 which is easily solved, But it's a 'point' source of heat, and unless I'm mistaken, I can't use this. The lecturer seemed to hint that it could be solved with looking at each side of the slab seperately. Any help? |
| Mar4-11, 12:52 PM | #2 |
I think the lecturer gave a good hint. Assume that the heat flux from Qvol is divided up between the left and right sides. For each side, you have a known temperature on one side and an unknown fraction of Qvol entering from the other side. Also, the fractions must add up to one. And finally, the temperature at the middle is the same in each equation. That should give you an equal number of equations and unknowns to solve the problem.
| Mar4-11, 07:46 PM | #3 |
So basically treat it as a series question?
Defining the temps as TL, TM and TR, (left, mid, right), Qin as the Q coming in from the left, Qmid as the heat through the middle, Qout as the heat from the right, a*Qvol as the fraction going into the left, a*Qvol as the fraction going into the right, L a the length with each side = to L/2: Qin - a*Qvol = Qmid Qout = Qmid + b*Qvol Qin = (Tm - T1)*(2A*k)/L so that Qmid = (Tm - T1)*(2A*k)/L - a*Qvol and (Fourier's Equation for the right side): Qmid = (T2 - Tm)*(2A*k)/L Solving the above two equations to get rid of Tm: Qmid = (T2 - T1)*(A*k)/L - (a/2)*Qvol So, Qout = (T2 - T1)*(A*k)/L + (b - a/2)*Qvol Qout = (T2 - T1)*(A*k)/L + (1 - 3a/2)*Qvol |
| Mar5-11, 11:16 AM | #4 |
Why 2A instead of A?
| Mar5-11, 05:11 PM | #5 |
2A because each side has length L/2 - so Ak/(L/2) = 2Ak/L.
Is the reasoning right? |
| Mar6-11, 11:15 AM | #6 |
Ah, got it. That part's OK, then. It's just that your last line looks a little off and I'm looking for problems in the calculations.
Why do you have Qin = (Tm - T1)*(2A*k)/L when Qin is defined as the heat transfer coming in? If Tm>T1, this predicts positive flux coming in from the left, which doesn't make sense. Then you have Qmid = (T2 - Tm)*(2A*k)/L; shouldn't this be Qout? (And again there seems to be a minus sign missing.) |
| New Reply |
| Thread Tools | |
Similar Threads for: Heat conduction through a slab with internal heat generation
| Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity | Advanced Physics Homework | 4 | ||
| Heat diffusion equation solutions for semi-infinite slab | Advanced Physics Homework | 1 | ||
| Heat generation | General Engineering | 4 | ||
| heat distribution in a slab | Introductory Physics Homework | 0 | ||
| Heat conduction | Introductory Physics Homework | 2 | ||
