Is a Shunt Resistor Necessary for a 12VDC, 40W Electromagnet Setup?
  • Thread starter Thread starter kfpanda
    Resistor Shunt
The discussion centers around the necessity and implementation of a shunt resistor or alternative protective components for a 12VDC, 40W electromagnet setup powered by a 12VDC, 5Amp power supply. Participants explore protection methods against potential arcing when switching the electromagnet on and off, considering the use of diodes versus resistors.
  • One participant questions the need for a shunt resistor and suggests using a catch diode to prevent arcing across the relay when it opens.
  • Another participant confirms that a diode is preferable for protecting against arcing and provides guidance on its placement and specifications.
  • There is a discussion about the appropriate type of diode, with emphasis on selecting one that can handle the full coil current briefly when the relay opens.
  • A participant calculates the current draw of the electromagnet based on its power rating and voltage, estimating it to be around 3.3 amps.
  • Some participants clarify that a standard diode is sufficient for this application, dismissing the need for a Zener diode.
  • There is a note on the importance of connecting the diode in reverse bias to ensure it only conducts during back EMF conditions.
  • One participant reassures that the power supply's capacity to deliver 5 amps is not an issue, as the relay will only draw the current it requires.
Participants generally agree on the use of a diode for protection against arcing, but there is no consensus on the necessity of a shunt resistor, as the initial question remains unresolved.
Participants discuss the implications of back EMF and the characteristics of the components involved, but there are no definitive conclusions on the optimal configuration or component values.
kfpanda
I have a 12vdc, 5Amp power supply and need to connect to a 12vdc, 40 watt electromagnet. I put a SPDT relay switch between the power supply and the electromagnet to turn it on and off. Do I need to put in a shunt resistor or something else to protect the magnet and the power supply? How do I figure out what value my resistor should be and where do I put it? Should I put it across the electromagnet or across the output of the power supply before the relay switch? Thanks
Why are you thinking that you need a shunt resistor?
And maybe instead of the resistor, you should put a big catch diode across the electromagnet coil? If you don't, when you open the relay, you could get some arcing across the relay, and possibly hurt your power supply...
So, a diode is better to protect arcing? what value do I need? I am a beginner and trying to learn to do this right. Thanks.
The diode will go across the coil in the opposite direction of the normal magnetizing current (point the cathode toward the +12V side). The diode will need to be able to support the full coil current briefly as the relay is opened. When the relay opens, the coil voltage will "fly back" in the reverse direction, and the diode will catch it at about -0.7V, keeping it from flying back to a high enough voltage to cause an arc. The coil current will be supported by the diode as it decays to zero. The time it takes to decay is approximately L/R, where R is the resistance of the coil.
So given the 40W power and 12V input voltage, what is the current of your coil when it is on? Pick a diode that can support that current as a peak current, and you should be okay. You can use the Digikey website, for example, to help you find candidate power diodes.
The spec of the electromagnet is 12v, 40watt. I am assuming 3.3 amp. it will use. Will I need a zener diode? Thanks.
No, not a Zener diode, just a vanilla diode.
http://en.wikipedia.org/wiki/Flyback_diode
Did you pick up on the fact that you need to connect the diode so that it is reverse biased (i.e.'backwards') so it doesn't conduct when operating normally? It will, however, conduct when the relay breaks the circuit and a back emf is generated by the falling current in the coil. Any 'rectifier' / power diode will do (as opposed to a small signal 'detector' diode).
I think you might be worried that the power supply can deliver 5 amps but the relay only uses 3.3 amps.
This is not a problem, as the relay will only take what it needs from the power supply and the extra current doesn't have to go anywhere else.
  • · Replies 28 ·
  • · Replies 28 ·
