Mass spectrometry - How can you find the mass of the compound?
  • Thread starter Thread starter Horseb0x
    Mass
The discussion focuses on identifying the parent peak in mass spectrometry to determine the molecular weight of a compound. It highlights the importance of using "soft" ionization methods to avoid fragmentation, allowing for the clear observation of the parent ion. Additionally, it emphasizes that mass spectra obtained under fragmenting conditions can provide valuable structural information. Techniques such as H1NMR, C13NMR, and IR spectroscopy are recommended to complement mass spectrometry for a comprehensive analysis.
  • Understanding of mass spectrometry principles
  • Familiarity with soft ionization techniques
  • Knowledge of H1NMR and C13NMR spectroscopy
  • Basic concepts of infrared (IR) spectroscopy
  • Research soft ionization methods in mass spectrometry
  • Learn how to interpret mass spectra for parent peak identification
  • Explore the use of H1NMR and C13NMR in conjunction with mass spectrometry
  • Study the role of IR spectroscopy in structural analysis of compounds
Chemists, analytical scientists, and researchers involved in compound identification and structural analysis using mass spectrometry and complementary techniques.
Horseb0x
The obvious way would be to look for the parent peak (the peak caused by the unfragmented molecular ion) at the end of the spectrum but how can you tell the parent peak from one caused by heavier isotopes? Also how do you know if there's a parent peak at all and that all the peaks aren't fragments? Are there any tricks I should know about for finding the molecular weight from the mass spectrum?
Chemistry news on Phys.org
There are ways of performing mass spectrometry that involve "soft" ionization methods that do not result in fragmentation. These methods can be used to determine the molecular weight of the species as only the parent ion will be present. Mass spectra obtained under fragmenting conditions can then be used to deduce structural features of the compound.
Using H1NMR, C13NMR and IR will help a great deal than using Mass spec by itself.
  • · Replies 0 ·
