Can Someone Help with Gaussian Beams?
  • Thread starter Thread starter Green Lantern
    Beams Gaussian
The discussion revolves around a problem related to Gaussian beams, specifically focusing on the characteristics of a He-Ne laser. The original poster seeks to determine the beam waist, the fraction of intensity within the Full Width Half Maximum (FWHM), and the angle of beam spread over distances.
  • The original poster attempts to relate the FWHM measurement to the beam waist and questions the assumptions regarding the wavelength of the laser. Participants discuss the definition of w(z) and its significance in the context of the problem.
Participants are actively engaging with the problem, clarifying definitions and exploring the relationships between various parameters. Some guidance has been offered regarding the assumptions that can be made about the wavelength of the He-Ne laser.
The original poster expresses uncertainty about the definitions and equations provided in their textbook, noting a lack of examples and clarity regarding the FWHM concept. There is also mention of missing information, such as the values of z and z(R).
Green Lantern
3. A laser scientist tells you that her He-Ne laser can be focused to a spot size of 5.00 microns. When pressed for details, she tells you that she got this number by measuring the Full Width Half Maximum (FWHM) of the intensity profile of the laser waist.
a) What is w(0) for this laser?
b) What fraction of the laser intensity is contained within the FHWM?
c) At what (full) angle will the beam spread over large distances, if one continues to measure the width of the laser beam to be the FHWM of the intensity?
[PLAIN]http://www.zemax.com/kb/content_images/fwhm/Equation1.jpg
[URL]http://upload.wikimedia.org/wikipedia/commons/thumb/5/53/GaussianBeamWaist.svg/350px-GaussianBeamWaist.svg.png[/URL]
From previous experience in a laboratory I know that the wavelength of a He-Ne laser is about 633 nm. I don't know if I can assume that for the purposes of this question. I'm using Laser Electronics 3E by Joseph Verdeyen and the book doesn't do a good job of explaining full width half maximum intensity. There's also no sample problems in the book or examples so I really can't tell if I'm doing it right. I don't know either z or z(R), although I can express z(R) in terms of w(0), but I don't know that quantity either. The equation for intensity above didn't come from my book. At least I didn't see it there. Am I supposed to use the 0.5 microns as w(z) for the intensity equation here?
I'm just going to bump this topic.
What does w(z) represent? I assume it's some sort of measure of the width of the beam, but how is it defined exactly?
The book here gives w(z) as the spot size. There is a minimum spot size at a certain point along the z-axis defined as z=0.
It's defined by this equation given in the OP:
[PLAIN]http://www.zemax.com/kb/content_images/fwhm/Equation1.jpg[/INDENT]
where I0 is the intensity at r=0. I0 and w are both functions of z. At the beam's focus, w takes on it's minimum value, denoted by w0.
Green Lantern, if you set I=I0/2 in that equation, you can determine what r is at the half-maximum points.
Yes, that is a reasonably valid assumption.​
Great. Thanks for the help.
