Frame velocity v. object velocity in derivation of 4-velocity
The discussion centers on the derivation of 4-velocity, specifically the relationship between proper velocity (η) and ordinary velocity (u) within the context of Lorentz transformations. Proper velocity is defined as η = u / √(1 - u²/c²), where u is the ordinary velocity of an object in a given frame. The transformation from frame velocity (v) to ordinary velocity (u) is clarified through the use of derivatives with respect to proper time, leading to the conclusion that the proper velocity components are expressed as (u^0, u^1, 0, 0) = (γ, γu, 0, 0), where γ = (1 - u²)^{-1/2}. The discussion resolves confusion regarding the transition from frame velocity to ordinary velocity, emphasizing the importance of understanding the reference frame in these calculations.
  • Understanding of Lorentz transformations
  • Familiarity with the concept of proper time and ordinary time
  • Knowledge of 4-vectors and their components
  • Basic grasp of special relativity principles
  • Study the derivation of Lorentz transformations in detail
  • Learn about the implications of proper time in relativistic physics
  • Explore the concept of 4-vectors and their applications in physics
  • Investigate the relationship between different reference frames in special relativity
Students and professionals in physics, particularly those focusing on special relativity, as well as educators seeking to clarify concepts related to 4-velocity and Lorentz transformations.
EricTheWizard
I've been learning about 4-velocity and all the "proper" 4-vectors recently, and if I understand correctly, proper velocity η (the 3-vector) is related to ordinary velocity by the relation [tex]\vec\eta = \frac{\vec u}{\sqrt{1-\frac{u^2}{c^2}}}[/tex], where u is ordinary velocity of an object within a certain frame, but that it is derived from the lorentz transformations for ordinary and proper time, which give the relation [tex]\frac{d\vec x}{d\tau} = \frac{d\vec x}{dt}\frac{dt}{d\tau}=\frac{\vec u}{\sqrt{1-\frac{v^2}{c^2}}}[/tex] where v is the velocity of the reference frame. What I don't understand is how v made this leap to u, or more clearly, how the frame velocity became ordinary velocity.
Not entirely sure what you're asking but I'll take a stab at it by thinking out loud..
Suppose we see some object moving at constant speed u along the x direction (just to make things simpler). To find out how fast its moving I take a derivative with respect to proper time, [tex]dx^{\beta}/d\tau[/tex] and it will have components [tex](u^0, u^1,0,0)=(\gamma, \gamma u,0,0)[/tex] where u is how fast I measure (using my clocks and rods) the object moving.
So what's in [tex]\gamma[/tex]? The speed u, so [tex]\gamma=(1-u^2)^{-1/2}[/tex] because that is what I observe. Also, you can check by working out the boost to the object's rest frame:
[tex] \bar{u}^{\alpha}=\Lambda^{\alpha}_{\beta}u^{\beta}[/tex]
which results in [tex]\bar{u}^{\alpha}=(1,0,0,0)[/tex] as it should.
So where are you getting your v? Is there another frame you're not including in your question?
Ahh I understand now, I had this picture in my head of some extraneous frame I guess I didn't need... Thanks for clarifying.
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 53 ·
  • · Replies 20 ·
  • · Replies 47 ·
