(Hopefully easy) integration question
  • Context: Graduate
  • Thread starter Thread starter lotm
    Integration
The discussion revolves around a specific integration problem involving a Fourier Transform of a Gaussian function. Participants are seeking clarification on the steps involved in the integration process and the transition between expressions. The scope includes mathematical reasoning and technical explanation.
  • Technical explanation, Mathematical reasoning, Homework-related
  • One participant expresses confusion about the integration steps and seeks clarification on how two lines of an equation follow from one another.
  • Another participant requests clarification on which specific lines are being referenced, indicating a lack of clarity in the original post.
  • A later reply suggests that the integration involves completing the square and using substitution, implying that the problem is manageable despite initial appearances.
  • There is an acknowledgment of the use of TeX code for formatting mathematical expressions, which some participants find challenging.
Participants do not appear to reach a consensus on the specific lines in question, and the discussion remains unresolved regarding the clarity of the original query and the integration steps.
Limitations include potential misunderstandings in the mathematical expressions due to formatting issues and the need for clearer communication of the specific lines being discussed.
lotm
Heyo,
I'm having difficulty seeing how these two lines follow. I'm fairly sure I'm being an eejit and the answer's straightforward, but would appreciate a quick explanation of what's going on.
[tex]\frac{1}{2\pi}\int d^3p e^{-i(\emph{p}^2/2m)t} \\ \times e^{i\emph{p.(x-x_0)}} \\<br /> = (\frac{m}{2 \pi it})^{3/2}e^{\frac{im(\emph{x-x_0}^2}{2t}}[/tex]
Thanks in advance.
Which two lines do you mean exactly?
I only see a single expression.
Yeah, I'm struggling a bit to get the tex code right. Screw it, I'll come back once I've figured out how to ask the question properly.
Do you mean:
[tex] \frac{1}{2\pi}\int d^3p e^{-i(\vec{p}^2/2m)t} <br /> e^{i\vec{p}\cdot(\vec{x}-\vec{x_0})} <br /> = \left (\frac{m}{2 \pi it}\right )^{3/2}e^{\frac{im(\vec{x-x_0})^2}{2t}}[/tex]
If that's the case then you can click on the equation to see the markup.
What you've got here, is a Fourier Transform of a Gaussian returning a Gaussian. It is easy though it might look daunting. Complete the square and use a little substitution and you'll be all set.
  • · Replies 21 ·
  • · Replies 19 ·
