Are Time Dilation and Length Contraction Proven by Experiments?
The discussion revolves around the experimental validation of time dilation and length contraction, concepts from special relativity. Participants explore the interdependence of these phenomena and the challenges associated with measuring them in different reference frames.
  • One participant inquires about the existence of experiments proving length contraction and time dilation, questioning their interdependence and the specifics of length contraction along different axes.
  • Another participant asserts that time dilation can be experimentally demonstrated through the twins paradox and mentions GPS satellites as practical examples that align with special relativity (SR) and general relativity (GR).
  • A different participant supports the idea that time dilation has been confirmed through experiments with high-speed rockets and atomic clocks, while suggesting that length contraction is more complex to measure but is inherently linked to time dilation.
  • One participant introduces the concept of relativistic mass increase and relates it to the broader context of experiments involving nuclear reactions, suggesting that these also serve as tests of special relativity.
Participants generally agree that time dilation has been experimentally validated, while the discussion on length contraction remains more contested, with differing views on its measurement and interdependence with time dilation.
Some participants express uncertainty regarding the measurement of length contraction and its dependence on the direction of motion, indicating that assumptions about the nature of these phenomena may not be fully resolved.
subir
are there any experiments to prove length contraction and time dilation?
are time dilation and length dilation inter dependent?
how can we say thaT THE LENGTH ALONG THE Y-AXIS DOES NOT CONTRACT
and from which side of the length contraction actually happens?
Time dilation is the easy one because you can actually perform the twins paradox experimentally and see that its true. In a way, GPS satellites are constantly performing the twins paradox and the results are consistent with SR (and GR) to a high degree of precision.
Length contraction is tougher because you measure the length in different frames at the same time. Its tough to convince people that what they are both seeing is "real." However, if it isn't real, the equations don't work.
As russ said, time dilation is an easy one. Experiments involving high speed rockets and airplanes, carrying one of two highly accurate and near perfectly aligned atomic clocks have been carried out, and the results agree to the predictions of SR to great accuracy. Length contraction is a lot trickier to measure experimentally, but it really isn't necessary. You see, if lengths didn't contract, or if they contracted along the y-axis as you suggested, then time dilation itself would be impossible, which we know isn't true from the previously mentioned experiments. Length contraction along the direction of motion is a direct consequence of time dilation, so by proving time dilation experimentally, we're also proving length contraction. So, to answer your question, they are interdependent.
I notice you didn't ask whether or not relativistic mass increase can be experimentally measured. In case you're wondering, since relativistic mass and the equation e=mc^2 are related in much the same way as time dilation and length contraction are related, then every atomic bomb or nuclear reactor is an experiment testing special relativity. So, the answer to that one is also yes.
  • · Replies 63 ·
  • · Replies 45 ·
  • · Replies 16 ·
  • · Replies 36 ·
  • · Replies 34 ·
