Calculate Density of Gas Mixture for Oil Burner
The discussion focuses on calculating the density of a gas mixture for an oil burner, specifically involving light heating oil (C12H23) with a density of 840 kg/m³ and air with a density of 1.185 kg/m³. The user seeks to determine the total density within the burning device under specific conditions, including a lambda value of 1.2, an oil injection pressure of 12 bar, and a maximum device pressure of 2 bar. The formula used for this calculation is mass = density × volume, leading to the equation den (Total) Vol (Total) = den (oil) V (oil) + den (air) V (air).
  • Understanding of gas mixture density calculations
  • Familiarity with the ideal gas law
  • Knowledge of lambda values in combustion
  • Basic principles of fluid dynamics in combustion systems
  • Research the ideal gas law and its application in density calculations
  • Learn about the significance of lambda values in combustion efficiency
  • Explore fluid dynamics principles relevant to oil burner design
  • Investigate methods for measuring density in gas mixtures
Engineers, combustion specialists, and anyone involved in the design and optimization of oil burners and combustion systems.
brajh11
Anybody knows how can i calculate the density of:
Light heating oil (C12H23): 840 kg/m3 and air: 1.185 kg/m3
The system is: oil burner in a small burning device and i want to calculate what density is in the inside the burning device.
I want to know the density for LAMBDA: 1.2
Operating conditions:
Pressure of oil injection is: 12 bar
Max. pressure of burning device is: 2 bar
Consider as total mass:
mass = density X volume = den X V
and solve for den (Total)
