The question is: Can GR be derived from the Einstein-Hilbert action?
  • Context: Graduate
  • Thread starter Thread starter friend
    Gr
The discussion centers on the question of whether General Relativity (GR) can be derived from the Einstein-Hilbert action, particularly in relation to a specific action proposed by Prof. Hagen Kleinert. Participants explore the implications of this action and its connection to the motion of particles in gravitational fields, as well as the broader dynamics of spacetime itself.
  • Prof. Hagen Kleinert's action suggests a relationship between particle motion and gravitational fields, but some participants question how this leads to GR.
  • One participant proposes that the action describes a test particle moving in curved spacetime, similar to how Mercury's motion is analyzed using the Schwarzschild metric.
  • Another participant emphasizes that the action describes particle motion rather than the dynamics of spacetime itself, which is governed by the Einstein-Hilbert action.
  • There is a distinction made between the geodesic motion of free-falling test particles and the derivation of GR itself.
  • Questions arise about the possibility of deriving general forms for actions from equations of motion, with references to inverse variation operations and functional integration.
  • Participants discuss the implications of different actions leading to the same classical solutions and the potential differences in quantum interpretations.
  • Concerns are raised about the interpretation of the differential element in the action integral and its relation to the concept of integrating over volumes in spacetime.
  • There is mention of the path integral formulation of quantum gravity and the challenges in defining the measure for metrics in this context.
  • The Ashtekar variables are introduced as alternatives to the metric, though details on their equivalence are not fully explored.
Participants express differing views on whether the action proposed by Kleinert can lead to a derivation of GR. While some see a plausible connection, others argue that the action does not suffice to derive the field equations of GR. The discussion remains unresolved with multiple competing perspectives.
Participants note limitations in the clarity of definitions and the interpretation of mathematical elements within the actions discussed. There are unresolved questions regarding the integration over spacetime and the nature of the paths in path integrals.
friend
Prof Hagen Kleinert suggested that the action (3)
[tex]\[A = \int_{{t_a}}^{{t_b}} {dt\frac{M}{2}{g_{\mu \nu }}(q){{\dot q}^\mu }{{\dot q}^\nu }} \][/tex]
can lead to GR. He writes, "Einstein's equivalence principle amounts to the postulate that the transformed action (3) describes directly the motion of the particle in the presence of a gravitational field caused by other masses." See the Webpage at:
http://users.physik.fu-berlin.de/~kleinert/kleiner_re252/node3.html#SECTION00021000000000000000
But he does not explicitly derive GR from this action. And I don't understand how he can make this claim. Can GR be derived from the above, and if so how? Thanks.
I think it is plausible if you take "in the presence of a gravitational field caused by other masses" to mean the particle in this Lagrangian is moving in the curved spacetime caused by an external mass. Sort of like solving for the motion of Mercury using the Schwarzschild metric for the effect of the sun, but we don't consider the smaller effects of the gravitation caused by Mercury.
You seem to be asking if one can derive the GR field equations for the metric from that Lagrangian. In that case I agree, it is not possible.
The above action describes how a test particle moves on curved spacetime. This is not special for GR but applies to all curved manifolds; a similar equation holds for a particle moving on a sphere.
The question in GR is not how to derive what happens to a test particle on spacetime, but what happens to spacetime itself. This dynamics is encoded in the so-called Einstein-Hibert action
[tex]S \sim \int \sqrt{-g}R[/tex]
where g means "determinant of the metric tensor" and R is the curvature scalar, calculated from contracting indices of the Riemann curvature tensor.
"Einstein's equivalence principle amounts to the postulate that the transformed action (3) describes directly the motion of the particle in the presence of a gravitational field caused by other masses." is not the same as "leading to GR". It just means that it leads to postulating the geodesic motion of a free falling test particle.
A list of actions for GR are found under the heading of "General Relativity" at http://www.phy.olemiss.edu/~luca/Topics/list.html
atyy said:
A list of actions ...?
This makes me wonder: is there a way to start with the equations of motion and work backward to find the general form for all possible actions? Is there an inverse variation operation, maybe functional integration?
friend said:
This makes me wonder: is there a way to start with the equations of motion and work backward to find the general form for all possible actions? Is there a inverse variation operation, maybe functional integration?
http://arxiv.org/abs/1008.3177
"It is worth noting that any system of equations can be derived from a variational principle: Simply multiply each equation by an undetermined multiplier, add them together, and integrate over spacetime (for PDE’s) or time (for ordinary differential equations). Such an action principle does not add any insights, and probably has no practical benefit. What we want in an action principle is an encoding of the equations of motion without the addition of any extra variables. Not all systems of equations can be derived from a variational principle using only the variables that appear in the original PDE’s."
A somewhat related point is that although different actions may lead to the same classical solution, the actions may differ when interpreted quantum mechanically. Eg. http://arxiv.org/abs/1012.4280 , which is speculative, but suggests that the application of asymptotic safety ideas leads to different theories depending on whether a metric action or the Holst action is used.
It's interesting that you did not include the differential element for your integral. Wikipedia shows a more complete version of the action as
[tex]\[S = - \frac{{{c^4}}}{{16\pi G}}\int {R\sqrt { - g} d{x^4}} \][/tex]
See:http://en.wikipedia.org/wiki/Einstein-Hilbert_action
I'm accustomed to seeing the action integral with respect to the differential dt, where t parameterizes paths of particles x(t), with start and ending points specified.
But I'm not sure what dx4 is supposed to mean, and I wonder how or if there is a starting and ending "volumes" as the limits of the integration in x4 space. I've read that the action integral integrates wrt volume when one is considering "mechanics of continua", where bulk properties are being considered. Is that what's going on with GR? Is GR a consideration of bulk volumes of spacetime?
Parameterized curves x(t) seem natural when considering path integrals of QM. But if one wanted to put this 4D Hilbert-Einstein action in the path integral to quantize gravity, how would one justify a path integaral when integrating with respect to x4 spacetime? Where is the "path"? Is the 3D volume being parameterized by t, from an initial to a final volume?
Yes, field theories (not necessarily quantum) have actions that are expressed in terms of Lagrangian densities:
[tex]S = \int_\Sigma d^4x ~\mathcal{L}.[/tex]
The Lagrangian is more properly defined as
[tex]S = \int dt~ L, ~~~ L = \int_X d^3x ~\mathcal{L},[/tex]
whenever the spacetime [tex]\Sigma[/tex] admits nice enough splitting as [tex]\mathbb{R}\times X[/tex].
For instance, the Maxwell equations are derivable from the action
[tex]S_{\text{EM}} = \int d^4x \left( -\frac{1}{4} F_{\mu\nu} F^{\mu\nu} \right),[/tex]
where [tex]F_{\mu\nu}[/tex] is a tensor constructed from the electric and magnetic fields.
The "paths" in a path integral formulation are essentially Riemannian metrics, so we'd write
[tex]Z = \int \mathcal{D} g e^{-S(g)/\hbar}.[/tex]
A complete definition of the measure [tex]\mathcal{D}g[/tex] is not known, but loop quantum gravity involves various methods to try to formalize the definition.
But it does not use the metric g as dynamical variable
The Ashtekar variables are supposed to be equivalent variables that replace the metric. I'm not very familiar with the details, but that is the general idea.
AEM gave a good set of references in https://www.physicsforums.com/showpost.php?p=2474351&postcount=16 . Tonti's papers are downloadable from http://www.dic.univ.trieste.it/perspage/tonti/papers.htm .
We had (and still have) long discussions in the "beyond forum" regarding LQG. The basic idea of LQG is that the Ashtekar variables are classical equivalent, but lead to an inequivalent quantum theory. That was one reason why Ashtekar started the business.
I suppose I should be more honest. When I say I'm not familiar with the details, I really mean that there are obvious inconsistencies that I've never had adequately explained to me. I thought it was worth mentioning LQG in the context, but that going into more detail than I did (none at all) wouldn't be helpful to the OP anyway.
I suppose that it's a good thing that the Ashtekar formalism is not quantum equivalent to GR, since the latter has incurable divergences. However, I am not entirely convinced that the classical theory is equivalent either. Since the diffeomorphism group is not completely generated by its algebra (at least in dimension 4), any attempt to account for all of the redundancies by gauging a spin connection is unlikely to result in the correct degrees of freedom. This is not strictly a classical problem, since the point is that the correct classical gauge symmetries are not present even in the classical prescription to translate between the metric and new variables.
The definition of the variables also involves introducing the Immirzi parameter, which is misleadingly claimed to to be fixed by black hole entropy calculations. I haven't followed every paper, but I believe that one requires different values for the Schwarzschild and Kerr-Newman BHs. I've also seen a recent paper on a quantum group calculation where the authors claimed that the BH entropy was completely independent of the Immirzi parameter. Whether the ambiguity is due to an inconsistency in the LQG prescription for computing the entropy or an even deeper problem.
I suppose I will find some of the older discussions you're referring to at some point, though I'm not sure that any of these topics would be addressed.
Your problem that the two formailsms are not equivalent classically is not due to the Ashtekar variables but due to the global foliation R*M³ which is possible with canonical gravity using the metric, too. So it's nozt on the level of variables but already on the level of the geometry. I would say that both formalisms are exactly equivalent in a certain subsector (e.g. excluding the Goedel cosmos with closed, timelike curves).
The Immirzi parameter is a quantization ambiguity that seems to be closed to the theta-angle in QCD and is reated to a topological term in the action. But there are also some differences and I agree that the issue has not yet been fully clarified.
But I agree that this is not relevant for the OP. Considering classical GR the Einstein-Hilbert action plus mathematical different formulation (like Palatini) are equivalent.
I guess I was asking about the necessity of the volume integral in the action. Is the curvature scalar, R, necessarily a bulk property? Could R also be calculated by, say, a line integral of some function over a closed loop? Or perhaps the ratio of a open surface to its closed boundary?
You could try to do those things, but then you should have a physical explanation of why the action depends on the choice of some submanifold. You would also be introducing background dependence, which means that we have to modify the definition of the action depending on what sources are present. By integrating over the entire volume, we avoid many potential problems.
In the case of a particle, the path integral is a weighted sum over all possible paths x(t).
In the case of a field, the path integral is then a weighted sum over all possible field configurations A(t,x).
In both cases, we are summing over all possible answers, ie. in the classical case, reality consists of one particular answer, which is x(t) for a particle and A(x,t) for a field.
The details on how the boundary is handled for the Einstein-Hilbert action can be found at http://www.physics.uoguelph.ca/poisson/research/agr.pdf
  • · Replies 50 ·
  • · Replies 20 ·
