Advice about preparing xanthates
  • Thread starter Thread starter chem_tr
The discussion revolves around the synthesis of xanthate derivatives, specifically focusing on the use of sodium hydride (NaH) and the feasibility of using acyl chlorides versus alkyl halides in the reaction process. Participants share experimental details, procedural advice, and alternative approaches related to the synthesis.
  • Experimental/applied
  • One participant plans to synthesize a xanthate derivative from an alcohol and carbon disulfide, seeking advice on using NaH and experimental details.
  • Another participant notes that NaH is effective but can be unpredictable, emphasizing the importance of adjusting calculations due to its dispersion in mineral oil.
  • A typical procedure for using NaH in the reaction is provided, with suggestions on stirring times and conditions.
  • Discussion shifts to the feasibility of using acyl chlorides instead of alkyl halides, with one participant expressing concern about the stability of the resulting product.
  • Another participant suggests that if an acid chloride can be made, it could be reduced to an alcohol and then exchanged for a halide using SOCl2 or PBr3.
  • There is a query about the effectiveness of NaBH4 or LiAlH4 in reducing acids, with a participant expressing caution about using LiAlH4 due to its reactivity.
  • One participant mentions that NaBH4 is typically not strong enough to reduce acids but suggests that NaBH4 combined with iodine may be more effective.
  • A reference is provided for the activated NaBH4, and a participant speculates on the mechanism involved in its enhanced reactivity.
Participants express differing views on the feasibility of using acyl chlorides versus alkyl halides, with some supporting the use of alkyl halides for stability while others explore the potential of acyl chlorides. The effectiveness of reducing agents like NaBH4 and LiAlH4 also remains a point of contention, with no consensus reached on their applicability.
Participants mention various conditions and assumptions regarding the stability of products and the effectiveness of reagents, but these aspects remain unresolved and depend on specific experimental setups.
chem_tr
Hello, I'm planning to synthesize a xanthate derivative from an alcohol and carbon disulfide. I will probably need to use sodium hydride to facilitate addition to the double bond, and I need advice about using NaH, and if possible, some experimental details about the reaction. I will look for Organic Syntheses Website for additional information, but your comments are also important for me.
Thank you
my 200thmessage :smile:
Chemistry news on Phys.org
NaH is a really nice reagent to use, although it is sometimes a little unpredictable (not in a dangerous way). Typically you get it as a 60% dispersion in mineral oil. That means that when you weigh it out only 60% of the weight is actually NaH, so adjust your calculations accordingly. Make sure that the NaH is a greyish color. If it's white it's probably no good. One other caveat to the mineral oil dispersion, depending on your solvent, you may need to wash the oil away with some hexanes. I've never had to do this myself though. If you're running your reaction in THF, then that is usually good enough to use without washing the NaH.
A typical procedure for using NaH would be something like this:
A mixture of NaH (88.0 mg, 2.2 mmol) was stirred in THF (3 mL) for 30 mins and then cooled to 0 degrees C. To the resulting slurry was added a solution of [amide] (2.0 mmol) in THF (1 mL). The resulting mixture was stirred at 0 degrees for 15 mins, then warmed to r.t. and stirred an additional 45 mins, and finally quenched with an appropriate electrophile.
You might not need to stir for that long since alcohols are more acidic than amides.
You should look up the Chugaev reaction, as that is what I assume you are doing. Check out this link: http://themerckindex.cambridgesoft.com/TheMerckIndex/NameReactions/onr74.htm
What about an acyl chloride?
Hello, I've been thinking of an acyl chloride now, as it is available, unlike the alkyl chloride of the reagent I'm planning. Movies, I'm waiting for your comments especially about the feasibility of the reaction, but other members are very welcome for any contributions. Please view www.students.itu.edu.tr/~akkurtb/misc/ksantat_acil_klorur.zip[/URL]
That reaction would probably happen as you have it drawn. The product would be very unstable though, since it is essentially an anhydride. There is a very real possiblity that you wouldn't be able to isolate that product.
You are right, Movies, it seems that I will have to find the alkyl halide derivative instead of synthesizing the acyl halide. The xanthate ester (with alkyl halide) is said to be stable up to several hundred degrees. It is better for me to pursue it in this way. Thank you for your kind suggestion.
If you can make that acid chloride (or ester or acid) then you should be able to reduce it to the alcohol and then exchange the alcohol for a halide with SOCl2 or PBr3.
With [itex]NaBH_4[/itex] or [itex]LiAlH_4[/itex] and so on, right? Exchange with [itex]SOCl_2[/itex] is an easy one, I've done this several times before. Actually, I have the acid on hand. Do acids give alcohols easily with these reagents? For example, may I use aqueous [itex]NaBH_4[/itex]?
NaBH4 isn't strong enough to reduce acids, usually. LiAlH4 can though. You might also try NaBH4 + I2, that can reduce acids but no one knows why it is so much more powerful than NaBH4 alone.
Here is a reference for the activated NaBH4: J. Org. Chem. 1993, 58, 3568-3571.
It possibly involves radicalic mechanism. Thank you for the reference, I'll read it. I didn't want to use [itex]LiAlH_4[/itex], since it is a "violent" reactant. But I can use it too.
11K
17K
  • · Replies 20 ·
